Results 1 to 29 of 29
Thread: front wheel bearing removal
  1. #1
    Seasoned Member Jim Ciampi's Avatar
    Join Date
    Nov 2003
    Location
    Virginia Beach,Va
    Posts
    234
    Default front wheel bearing removal
    I need to remove my front wheel bearing.I looked in Honda Direct and a bearing removal head made by Honda is not available.I have a metal lathe and could probably make one if I could see one close up.The service manual shows one,but no help there.I wouldn't mind buying one if I could locate where. Any help would be appreciated. Thanks Jim
    Do what you want,but be willing to pay the dues
    http://image1.
  2. #2
    Seasoned Member Quickdraw's Avatar
    Join Date
    Jan 2004
    Location
    Olympia, Washington
    Posts
    4,652
    Default
    Try you local Honda dealer.
    I have been able to remove them, for replacement, with a small dull chisel.
    Quickdraw
    "Ride Hard to Get Lost"
    AMA 677688 . MSF 27471
    IBA 16909 (2XSS1K, 1XBBG)
    1st Place - Spring Fling Rally '05
    Yellow Spot III
  3. #3
    Seasoned Member Fred H.'s Avatar
    Join Date
    Nov 2003
    Location
    Texas
    Posts
    15,364
    Default
    Jerry R. suggested taking about a foot of round alluminum tubing stock of the proper diameter to just fit inside the bearings, and slicing (hacksaw) it lengthwise about 1/3 of the way it's length. Then you can spread the section of two halves where you cut just a bit, and then slide it into the wheel so the lip catches on the edge of the bearing. Then you should be able to drive it right out.
    I have not tried it, but it sounds like it would work, and next time I remove mine, this is what I will do.
    Fred H.
    GL1800 Maintenance Videos
    Motorcycle Consumer News Review
    I now work on GoldWings in the Dallas/Fort Worth area - Contact me for an appointment
  4. #4
    Seasoned Member Jerry J's Avatar
    Join Date
    Nov 2003
    Location
    Indiana, New Paris
    Posts
    842
    Default
    Yellow Wolf said that he changed his using a little heat. Since then I seen a report by a guy who was changing the bearings on his BMW and said he used a little heat like you are suppose to ? Now you all know that the aluminum wheel is going to expand like crazy with a little heat and the steel bearing won't. My guess is that it would drop out at about 200 degrees?? Anyway I will probably change mine this week and after I get the tire and valve stem off I will be seeing if that sucker will fit in the kitchen oven!! Also by using a little heat you won't be damaging the bearing pocket by forceing the bearing out.
    Flame suit on guys give me hell ----
    1968 Honda 305 scrambler
    1965 BSA 650 lightning
    1977 Kaw KZ1000
    1981 Honda 1100 Goldwing
    1999 Kaw 1000 concours
    2001 Honda 1800 Goldwing
    2008 Honda 1800 goldwing
    Jerry J 2008 Pearl White
    IBA 22807
  5. #5
    Join Date
    Apr 2004
    Location
    Mo, Kansas City
    Posts
    1,766
    Default
    I have chaged several set now. All I do is use a small propane torch to heat the area right around the bearings.
    In about 20 seconds, they fall right out.
    Not hot enough to hurt the wheel and less painful than buying the $180 tool from Honda
    There is a very fine line between "hobby" and "mental illness."
  6. #6
    Join Date
    Nov 2003
    Location
    Indiana, New Paris
    Posts
    842
    Default
    Thank you fluf, all you people who have been doing this for the last 3 or 4 years and not saying anything are ------- chickens I've been wondering about this since 2001 and wondered why nobody was saying anything about it
    1977 Kaw KZ1000
    IBA 22807
  7. #7
    Join Date
    Apr 2004
    Location
    Mo, Kansas City
    Posts
    1,766
    Default
    Quote Originally Posted by Jerry J
    Probably because, like me, they don't like being called stupid. But Hey, it works. Wheels aren't hurt and now its kind of fun coming out ot the closet
  8. #8
    Join Date
    Nov 2003
    Location
    Indiana, New Paris
    Posts
    842
    Default
    Better get ready fluf, Fred and Art mann are going to eat your lunch. Hell you probably warped your wheel or changed the molecular composition of the aluminum---- throed it out of balance-- who no's
    1977 Kaw KZ1000
    IBA 22807
  9. #9
    Join Date
    Apr 2004
    Location
    Mo, Kansas City
    Posts
    1,766
    Default
    I'll just hide behind door #3
  10. #10
    Join Date
    Mar 2004
    Location
    Henderson,NV
    Posts
    417
    Default Home Made Tool
    Jim
    I'll email you a picture of my tool. I made it from a Craftsman 1/2" deep well impact socket. It worked fine for me. You will need a lathe.
    John
  11. #11
    Seasoned Member Bulldog's Avatar
    Join Date
    Nov 2003
    Location
    NY, Woodbourne, Home of "Shin-Grips"
    Posts
    13,331
    Default
    Blizz,
    Hows about helping anothe USAF retiree out? I would like a copy of your Socket/Tool as well.
    Thanks in Advance.
    Bulldog
  12. #12
    Join Date
    Mar 2004
    Location
    Henderson,NV
    Posts
    417
    Default Photo
    BullDog
    Would be more than happy to. I'm unable to send it via this forum or it's email system. Tried to send it to Jim, but I'm just not smart enough to figure it out. Although I can make the tool...
    Send me a real world email address and I'll send it. If you can post it, the picture I meant, please do.
    John
  13. #13
    Join Date
    Apr 2005
    Location
    Plaistow, NH
    Posts
    725
    Default
    This is the greatest stuff I ever used. I have used it on my planes corvettes and many bikes. I even shimne my shoes with it.
    I bought a gallon two years ago and still have a quart left.
    I carry some in a small squirt bottlwe on the bike. At the price you can't beat it. Believe me it is super stuff. Also clean chrome etc
    http://www.washwax.com/
  14. #14
    Seasoned Member Pigeon Roost's Avatar
    Join Date
    Jan 2004
    Location
    Logan, WV
    Posts
    10,767
    Default
    I think Fred got his hotter than any propane torch could when he did his by welding a round bar to the bearing. The propane should be safe, if consistently effective -- a painter's heat gun may do the same -- don't ya think?
    2002 Black Standard Brakes "TE MEGA MONTY"
    DARKSIDER #1249
    "Well, Chester; choos'n friends goes kinda fast once the shoot'n starts." Mathew Dillon to Chester Goode
  15. #15
    Join Date
    Jan 2004
    Location
    Logan, WV
    Posts
    10,767
    Default
    Another question, why are these wheel bearing failing so commonly -- or is that you are powder coating or chroming the wheels?
    DARKSIDER #1249
  16. #16
    Join Date
    Apr 2004
    Location
    Mo, Kansas City
    Posts
    1,766
    Default
    Quote Originally Posted by Pigeon Roost
    I am just doing it on the exchange wheels I am getting for choming and powder coating.
    I don't know of any that have failed.
  17. #17
    Join Date
    Mar 2004
    Location
    Henderson,NV
    Posts
    417
    Default
    I changed mine because after three new sets of tires, I was still getting a buzz from the front when I leaned off center. That was over the last two + years.
    Did it fix it? Maybe... I think some of it went away. Key word here is...Think... The human mind can play some tricks on you when you want something to change and you've spent time and money to fix something that is subjective. Would I do it again? Yea...
    John
  18. #18
    Join Date
    May 2004
    Location
    Vancouver, B.C.
    Posts
    183
    Default
    I'd be careful with heat on aluminum as it will anneal it (make it softer and weaker).I once heard of a diver who painted his air tank some funky colour and then baked it in his oven for a while.Next time he filled the tank it blew up. Heat is not the answer on an aluminium wheel.
    The only stupid question is the one you didn't ask.
    2006 Red GL1800A
  19. #19
    Join Date
    Sep 2004
    Location
    Kirkwood, Missouri
    Posts
    358
    Default
    Quote Originally Posted by fluf
    I ordered the removal tool from my dealer (actually 2 different pieces) and it was only about $30
    Worked like a charm.
    Ride Safe - Ride Often,
    Duane
    '04 Candy Black Cherry
    '06 CBR 1000RR Red/Black
    '05 Shadow VLX Deluxe - Pearl White (Wife's)
  20. #20
    Join Date
    Apr 2004
    Location
    Mo, Kansas City
    Posts
    1,766
    Default
    Quote Originally Posted by White Rat
    my dealer told me $180, can my email me the part numbers please
    thefluff@sbcglobal.net
    Thanks a bunch in advance
    Jeff
  21. #21
    Join Date
    Sep 2004
    Location
    Kirkwood, Missouri
    Posts
    358
    Default
    This was from a post by Brian Fenner, I believe:
    Bearing Removal:
    07746-0050100 - REMOVER,BRG.....$14.89 x 1 = $14.89
    07746-0050600 - REMOVER,HEAD 20MM....$14.63 x 1 = $14.63
    Bearing Installation:
    07749-0010000 - DRIVER....$15.63 x 1 = $15.63
    07746-0010300 - ATTACHMENT (42X47MM)....$10.31 x 1 = $10.31
    07746-0040500 - PILOT20MM....$5.09 x 1 = $5.09
    Duane
  22. #22
    Join Date
    Nov 2003
    Location
    Texas
    Posts
    15,364
    Default
    Actually, I just welded a very small bead onto the bearing itself. I was on and off the bearing in less than 3 seconds. I doubt I got it anywhere close to as hot as a propane torch would.
    All I needed was just enough metal on the inside diameter of the bearing to catch on the edge of my socket I inserted so I could drive them out.
    And by the way, I DO NOT recommend this approach. I was getting desperate. You would be dollars and sense ahead to spend the $30 on the tool.
    Fred H.
  23. #23
    Join Date
    Apr 2004
    Location
    Mo, Kansas City
    Posts
    1,766
    Default
    This was from a post by Brain Fenner, I believe:
    Bearing Removal:
    Thank you so much.
    I will order the stuff in the AM
    Jeff
  24. #24
    Join Date
    Nov 2003
    Location
    IN, Indianapolis
    Posts
    275
    Default
    I use a 3/4" expansion bolt anchor. Costs $5. Insert the end in the bearing, tighten the nut which expands the anchor, tap on it with a 3/4" bolt from the opposite side and out will come the bearing.
    Shooter Indy
  25. #25
    Join Date
    Nov 2003
    Location
    CA. Aptos/Santa Cruz
    Posts
    809
    Default 3/4" expansion bolt anchor
    Shooter......What the heck is a " 3/4" expansion bolt anchor " ??
    Never seen one
  26. #26
    Seasoned Member CJS's Avatar
    Join Date
    Jul 2004
    Location
    Grand Rapids, Michigan
    Posts
    5,035
    Default Re: 3/4" expansion bolt anchor
    Quote Originally Posted by Eagle Eye
    Never seen one
    Probably something like this. Should be availabe at Home Depot or Lowes
  27. #27
    Join Date
    Nov 2003
    Location
    Posts
    809
    Default
    Damn......I've got about 20 of those under my work bench.
  28. #28
    Join Date
    Nov 2003
    Location
    Texas
    Posts
    15,364
    Default
    Excellent Idea !!!! Great suggestion! Next time, I will do this.
    Fred H.
  29. #29
    Join Date
    Nov 2003
    Location
    IN, Indianapolis
    Posts
    275
    Default
    Stud Bolt Sleeve Anchor is the technical name.
    Shooter Indy
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not edit your posts
