What kind of liscence for Trike in your state
+ Reply to Thread
Results 1 to 11 of 11
Thread: What kind of liscence for Trike in your state
  1. #1
    Join Date
    May 2007
    Location
    Claremore, Oklahoma
    Posts
    416
    Post Thanks / Like
    Default What kind of liscence for Trike in your state
    This is being discussed on the VTX board, I was surprised to see some states consider a trike needs a car driver's liscence and isn't considered a motorcycle (CA and UT) I wonder if its because there are alot of trikes with car engines?
    So I'm curious, in your state do you have a motorcycle endorsment and tags for your trike? Oklahoma does!
    Riding on the Wing(s) of an Angel
    "Angel" a 05 GL1800 30TH ANNIVERSARY SPECIAL EDITION with an 07 CSC trike kit Candy Black Cherry
    "the Girlfriend" 04 VTX 1800 Candy Black Cherry
    Matching Trailmaster Arizona Trailer
  2. Advertisements
  3. #2
    Seasoned Member WNGNUT's Avatar
    Join Date
    May 2005
    Location
    Rhodes, Iowa
    Posts
    873
    Post Thanks / Like
    Default
    This is the definition from Iowa Code section 321.1
    40. a. "Motorcycle" means every motor vehicle having a saddle or seat for the use of the rider and designed to travel on not more than three wheels in contact with the ground including a motor scooter but excluding a tractor and a motorized bicycle
    VFW Life Member# 9445777
    Darl
    2001 Pearl Blue 1800
    2008 Victory Vegas Jackpot Arlen Ness Edition
  4. #3
    Join Date
    Jan 2006
    Location
    Newcastle England UK
    Posts
    577
    Post Thanks / Like
    Default
    In the UK you can ride a trike on a full car(cage) license you do not need to have a motorcycle license.
    2005 GL1800 ABS
  5. #4
    beastie
    Guest
    Default
    In Ohio, you can ride a trike (defined as a 3 motorcycle) if you have a motorcycle license. You cannot ride a trike with just a car license.
    However, you can get a 3 wheel endorsement on you car license id you pas the 3 wheel motorcycle test. With the 3 wheel endorsement, you cannot ride a motorcycle.
  6. #5
    Seasoned Member yellowtrike's Avatar
    Join Date
    Aug 2005
    Location
    Pahrump, NV
    Posts
    1,406
    Post Thanks / Like
    Default
    In California if you ride and motorcycle with a sidecar OR a trike you are not required to have a motorcycle endorsement on your driver's license.
    The vehicle is still licensed as a motorcycle.
    Suz
    03 Yellow Motortrike
  7. #6
    Dangerous Old Lady Biker S&W Winger's Avatar
    Join Date
    Jan 2006
    Location
    South Florida
    Posts
    5,923
    Post Thanks / Like
    Default
    Florida you need the motorcycle endorsement and the course before the license...
    Beverly
    IBA, AMA, mostly GL1800riders.com member!
    Silver '07 Gold Wing, RIP-carried me far just not safely around that cow
    Blue '07 Uplander Entervan-with help from my GL1800 friends!
    for Jerry
    Thank you for your support!
    FL Prowler #1800
  8. #7
    Join Date
    Mar 2006
    Location
    North Easton MA.
    Posts
    170
    Post Thanks / Like
    Default
    Mass still considers the trike a motorcycle thus you need an indorsement or just a motorcycle licence
    Don Dion
    Easton Mass
    2002 orange 06 CSC
    07 Bustec
  9. #8
    Seasoned Member Wilson's Avatar
    Join Date
    Nov 2003
    Location
    Church Point, LA
    Posts
    1,142
    Post Thanks / Like
    Default
    Louisiana requires the MC endorsement to ride a trike.
    Ride Safe, Ride Often
    Wilson Boudreaux
    from Cajun Country
    http://picasaweb.google.com/WilBoud
    Acadiana SCRC #239 Road Captain
    '05 Wing CSC Trike Dark Grey Metallic (Blue Steel)
    '05 Royal Star Tour Deluxe Black/Red (Raven)
  10. #9
    IBTrike
    Guest
    Default
    Michigan. Motorcycle endorsement on drivers license req'd. Registered the same as a motorcycle. They don't even differentiate between a 2 wheeler and a trike. As far as the State is concerned, they are the same animal.
  11. #10
    SOB First Shirt SMSgtE8's Avatar
    Join Date
    Sep 2004
    Location
    Commerce, Georgia
    Posts
    943
    Post Thanks / Like
    Default
    Georgia:
    40-15-1. Definitions
    (5) "Motorcycle" means every motor vehicle having a seat or saddle for the use of the rider and designed to travel on not more than three wheels in contact with the ground, but excluding a tractor and a moped.
    40-5-23. Classes of licenses
    Class M -- Motorcycles, motor driven cycles, and three-wheeled motorcycles;
    Bill & Sandy Hatfield
    Illegitimi Non Carborundum
    2005 White w/2005 Champion Trike
    http://www.patriotguard.org/Home/tabid/53/Default.aspx
    GeorgiaCarry.org Member
  12. #11
    Contributing Member
    Join Date
    May 2005
    Location
    Colchester, VT
    Posts
    57
    Post Thanks / Like
    Default license
    In Vermont, you only need to pass the written motorcycle test to ride a trike. The skills test on a trike would be a moot point. MSF class still a good idea.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
