Need Help with Rear Wheel Removal on 1100 V-Star
+ Reply to Thread
Results 1 to 8 of 8
Thread: Need Help with Rear Wheel Removal on 1100 V-Star
  1. #1
    Join Date
    Nov 2003
    Location
    Clarksdale, Ms
    Posts
    180
    Post Thanks / Like
    Default Need Help with Rear Wheel Removal on 1100 V-Star
    Hi!
    How do you get the rear wheel off the 1100 V-Star? I am putting on new tires for a lady in our Motorcycle Club and have run into a serious problem! After pulling the axle and the brake caliper the wheel could not slide over far enough to remove due to the bracket that holds the brake caliper being in the way. The only way I can see to get the bracket out is to first remove the brake disc. Is that the correct procedure? So, I begin removing the allen head bolts holding the disc on and one of the socket heads stripped out! I have not yet been successful in removing the bolt. Any ideas? Is there a better way to remove the wheel? I sure wished she had a shop manual! Thanks!
    Donnie
    Donnie
    2007 KLX250S - 4,450 Miles
    2002 KLR-650 - 67,420 Miles
    1996 BMW GS - 60,840 Miles
    2002 Goldwing - 230,841 Miles
    Sam Hearn's Last Ride - The Trans American Trail:
    http://www.advrider.com/forums/showthread.php?t=596373
    My Wife And I Ride Mexico For A Month:
    http://www.advrider.com/forums/showthread.php?t=550086
  2. Advertisements
  3. #2
    Seasoned Member Roadie's Avatar
    Join Date
    Nov 2003
    Location
    Bear, Delaware
    Posts
    4,495
    Post Thanks / Like
    Default
    Go to this V Star forum and ask them
    http://forums.delphiforums.com/yamaha11 ... ing+%3E%3E
    Frank
    Bear, Delaware
    03 Candy Orange
  4. #3
    Seasoned Member Brian Hand's Avatar
    Join Date
    Nov 2003
    Location
    Tx. Corsicana
    Posts
    1,400
    Post Thanks / Like
    Default
    Try letting the air out of the tire and see if it will pass by.
    No matter where I go here I am.
  5. #4
    Join Date
    Jun 2005
    Location
    Buffalo Grove, IL
    Posts
    623
    Post Thanks / Like
    Default
    I did mine over the July 4th week. And yes, a shop manual helps. Brake disc removal is not necessary.
    In addition to removing the brake caliper you also need to remove the caliper bracket. Once you do, the rear wheel will slide out.
    When re-installing, be sure you lube the drive shaft worm gear with Moly grease.
    Ellary
    '01 GL1800A
    150,000 mile club
    '99 V-Star 1100
  6. #5
    Join Date
    Nov 2003
    Location
    Clarksdale, Ms
    Posts
    180
    Post Thanks / Like
    Default Thanks!
    I have finished the tire change. Thanks!
    Donnie
  7. #6
    Veteran Member wingwing's Avatar
    Join Date
    Nov 2006
    Location
    Agrestic, Florida WW/MM
    Posts
    10,965
    Post Thanks / Like
    Default Re: Thanks!
    Quote Originally Posted by dwj
    So ... what was the secret?
    Dennis
    Life..DS#99/Prowler#0
    It is difficult to be on the right side of science, but on the wrong side of ideology ~ sg
    All truth is at first ridiculed, then opposed, and finally, self-evident (
    two
    down, one to go).
    ..THE REVOLUTION HAS BEGUN..
    Ride Safe, Avoid R.U.D.
  8. #7
    Join Date
    Apr 2005
    Location
    BOUNTIFUL UTAH
    Posts
    3,611
    Post Thanks / Like
    Default
    SHUSH.. ......IT'S A SECRET
    later..Randy
    later...Randy
    2005 Goldwing Dark Gray Metallic... It's Gone To A New Owner.
    ...GUN CONTROL IS HITTING YOUR TARGET...
    PROUD MEMBER OF THE PATRIOT GUARD RIDERS
  9. #8
    Seasoned Member CBXMan's Avatar
    Join Date
    Aug 2006
    Location
    Vinson Massif
    Posts
    1,813
    Post Thanks / Like
    Default
    Take 2 bolts out of caliper and hang it up
    Unbolt caliper bkt from swing arm
    Take off axle nut
    Take out 4 bolts holding differential in swing arm
    Unbolt axle holder on right side
    Pull rear end, wheel, axle, & caliper bkt straight back & off the bike
    Pull axle, caliper bkt & spacer out
    Separate wheel from rear end
    There's a long spacer in the rear end that can fall out, keep an eye out for it
    It may sound like a lot of trouble to pull the rear end out, but after the rear end of the bike is jacked up, it takes less than 5 minutes to get the wheel off. Different brands of pipes can get in the way.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
