CASTROL SYNTHETIC Oil
+ Reply to Thread
Results 1 to 14 of 14
Thread: CASTROL SYNTHETIC Oil
  1. #1
    Seasoned Member Snazzy Nazzy Biker's Avatar
    Join Date
    Jan 2004
    Location
    Otis Orchards, Wa.
    Posts
    510
    Post Thanks / Like
    Default CASTROL SYNTHETIC Oil
    Does anyone on the board use or know something about Castrol Synthetic Oil for use in the GL1800????
    I have used regular Castrol 20-50 for the life of the bike, . . . . but thought I would try the "synthetic". If you have info, . . . I would appreciate hearing about it. Thanks
    Thank a Teacher if you can read this -- Thank a VETERAN for making it in English!
    Praises & Thank-you's to all the People serving in our MILITARY!
    02 Silver with/ NO CRACKS, NO DRIPS, NO ERRORS!
    DO SOMETHING GOOD IN YOUR LIFE, THAT WILL “OUT-LIVE” YOU!
  2. Advertisements
  3. #2
    Chard Member
    Join Date
    Nov 2003
    Location
    Clearwater, Fl
    Posts
    11,777
    Post Thanks / Like
    Default
    I've used the Castrol 20/50 Blend for years. I've tried the Castrol 20/50 full synthetic a couple times, but I thought the blend made the Wings shift smoother. YMMV...
  4. #3
    IBTrike
    Guest
    Default
    Any oil that meets the JASO T903 MA spec (it will be so stated on the bottle) will be fine, as long as you follow the weight recommendation for your riding conditions. 10W-40 is good for most conditions.
    Do not use any oil that is called "energy saving", as it may contain moly, and can screw up your wet clutch. Such oils will NOT be certified JASO T903.
    IMHO, pure synthetic oil is very expensive, and there isn't any advantage in using it in touring bike.
    Ride safe.
  5. #4
    Join Date
    Feb 2005
    Location
    Lone Grove, Okla
    Posts
    762
    Post Thanks / Like
    Default
    I have used Castrol 10-40 full synthetic for quite a while. I have found it on sale for 5$ a quart and bought a case at a time.[12 bottles] My bike shifts as good as when I tried Amsoil, and is considerably cheaper.
    I don't know if it is really any better than any other oil or not, but you have to choose something and I chose it. I change at 5000 miles because I feel better than longer intervals.
    '08 Pearl White CSC
    '04 Black GL1800
    '04 Black Escapade Elite
  6. #5
    Join Date
    Nov 2003
    Location
    Independence Ohio
    Posts
    17,681
    Post Thanks / Like
    Default
    A word of warning about Syntec 20/50. I did some research on this last week when a similar Castrol topic came up.
    Syntec 20/50 contains elevated levels of zinc and was created specifically for older classic cars. Castrol recommends that it not be used in any vehicle built after 1993.
    Larry
    2002 Illusion Blue GL1800
  7. #6
    Join Date
    Apr 2006
    Location
    Georgia
    Posts
    379
    Post Thanks / Like
    Default
    Castrol 10W40 synthetic here.
    No problems.
    2006 Honda Goldwing,titatium with GPS Navigation.
    2004 VTX 1800C,titatium flame paint,K&N air filter.studded stock seat with honda deluxe backrest with rack.
    2006 Suzuki Hayabusa,pearl white paint.Yoshimura titatium bolt on exhaust cannisters.
    1982 Kawasaki KZ1000 LTD, black paint original,K&N air filter.
  8. #7
    Member
    Join Date
    Jul 2007
    Location
    James Creek, PA
    Posts
    2
    Post Thanks / Like
    Default First Oil Change
    Doing my first oil change. I wanted to use Castrol Synthetic, but it only seems to be available in the "energy conserving" style. Is there a secret Castrol Sythetic that I don't know about?
  9. #8
    Contributing Member
    Join Date
    Jul 2007
    Location
    Solon, Ohio
    Posts
    35
    Post Thanks / Like
    Default Is the 20/50 blend appropriate for any climate?
    Quote Originally Posted by Red
    You live in a hot Florida climate. Do you think this same Castrol 20/50 blend would be appropriate for the cold northern climate? I plan on riding from about March 15 to December 1 in any given year. It can be quite cold late November. I am hoping the heated grips and seats will allow me to ride for at least another month out of the year than what I use to do onmy old bike.
    As far as oil, I have read a few of the forum threads on dino vs synthetic oil and have no clear opinion on what is best in a motorcycle. I guess either is fine, kind of depends on what makes you think is best.
    2007 GL1800 Comfort/NAV (21k miles)
    1996 Suzuki VS800 (30k miles)
    Trek bicycle (5k miles)
  10. #9
    Join Date
    Nov 2003
    Location
    GA, Atlanta
    Posts
    1,323
    Post Thanks / Like
    Default Re: CASTROL SYNTHETIC Oil
    Quote Originally Posted by Snazzy Nazzy Biker
    ...If you have info, . . . I would appreciate hearing about it. Thanks
    It's been my experience that most bikes like one brand better than another. My '05 did not like the Castrol synthetic motorcycle oil...rougher shifting and slipped out of fifth gear from time to time.
    Your results may be much different.
    8th & I - '73-'75
  11. #10
    Seasoned Member I SPY's Avatar
    Join Date
    Nov 2003
    Location
    Somewhere in Utah......or maybe not
    Posts
    250
    Post Thanks / Like
    Default
    On the recommendation of the local Honda GW mechanic, I've used Castrol SYNTEC 20/50 for several years. It is petroleum based by the way. Good oil...Smooth shifing, etc. At 52K I switched to Dawg's AMSOIL and I like it better. JMHO.
    I SPY
    '01 CSC Cobra...Black
    '08 HD FLHT Electra Glide...Black (of course)
    TRIKES & BAGGERS RULE !!! Get used to it.
  12. #11
    Veteran Member wingwing's Avatar
    Join Date
    Nov 2006
    Location
    Agrestic, Florida WW/MM
    Posts
    10,965
    Post Thanks / Like
    Default
    Quote Originally Posted by I SPY
    I'm coming to the same conclusion.
    After using the AmsOil the bike shifted MUCH better.
    Then I tried using other oils to see if further shifting improvments could be had
    ... I'm about out of oils to try and found nothing better for shifting
    (I don't think the engine cares what you use)
    Next oil change will be back to AmsOil.
    Dennis
    Life..DS#99/Prowler#0
    It is difficult to be on the right side of science, but on the wrong side of ideology ~ sg
    All truth is at first ridiculed, then opposed, and finally, self-evident (
    two
    down, one to go).
    ..THE REVOLUTION HAS BEGUN..
    Ride Safe, Avoid R.U.D.
  13. #12
    Seasoned Member Justa_Poser's Avatar
    Join Date
    May 2007
    Location
    Missouri
    Posts
    2,976
    Post Thanks / Like
    Default
    Quote Originally Posted by LarryM
    If you look at the formulations for motorcycle and diesel oils you will find that they have higher zinc and phosporus levels than most automotive oils. Elevated zinc levels is a good thing when it comes to lubrication.
    In fact - Mobil brought back their 15W-50 synthetic oil last year with a similar formulation. More phosporus, more zinc. A closer formulation to a motorcycle specific oil.
    Current Inventory:
    '08 Fat Boy
    '10 GL1800
    '13 FJR1300
    '13 Victory Boardwalk
    '14 Kawasaki Versys
    '15 Heritage Softail
  14. #13
    Seasoned Member mrbill21's Avatar
    Join Date
    Oct 2004
    Location
    Broken Arrow, Ok
    Posts
    702
    Post Thanks / Like
    Default
    I used the 15-50 Syntec for 12 years/100,000 miles in my GL1500. Very satisfied. I now use Mobil 1 in my 05, no good reason for the change.
    "Ah, beer. The cause of, and the solution to, all of life's problems." Homer Simpson
    GWRRA Level 4
    GWRRA 69455
    IBA 14647
    2009 GL1800LE blue with 17K miles "FOR SALE"
    2005 GL1800A bright silver with over 136k smiles
    1999 Silver Bushtec Turbo+2
  15. #14
    Join Date
    Jan 2004
    Location
    Otis Orchards, Wa.
    Posts
    510
    Post Thanks / Like
    Default
    Thanks guys for your responses . . . . . . . .
    I have noticed an improvement in the shifting of my bike. So, . . . for at least awhile, I am going to try this with not much reservation. I appreciate all of your "experience" on the subject.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
