Best cost effective way to seal floor in a cargo trailer
+ Reply to Thread
Results 1 to 18 of 18
Thread: Best cost effective way to seal floor in a cargo trailer
  1. #1
    Seasoned Member Dan's Avatar
    Join Date
    Jun 2007
    Location
    Central Texas
    Posts
    1,124
    Post Thanks / Like
    Default Best cost effective way to seal floor in a cargo trailer
    Anyone sealed their floor in their enclosed trailer?? I'm not sure if paint is best. Looking at the expoxy seal used on garage floors but it seems to be for concrete only. What about the "hot tire" issue on most of the floor paints disclosures?
    The Rhino Liner bed liner route seems expensive.
    Any suggestions????
    Iron Butt Member #38163
    Darksider #797 running Michelin Primacy Alpin 195/55/16 at 32 psi
    Bridgestone Battleax BT45 on front @ 40 psi.
  2. Advertisements
  3. #2
    Join Date
    Dec 2006
    Location
    Port Arthur, Tx
    Posts
    677
    Post Thanks / Like
    Default
    Rhino is real easy to roll on a floor. And can be found in the Auto parts stores for about the same as the other floor paints and a lot tougher.
    A smile is very contagious. Pass this on.
  4. #3
    Join Date
    Jun 2007
    Location
    Central Texas
    Posts
    1,124
    Post Thanks / Like
    Default
    I didn't know there was a roll on version of Rhino liner. I always thought it was sprayed on with heat.
  5. #4
    Join Date
    Dec 2006
    Location
    Port Arthur, Tx
    Posts
    677
    Post Thanks / Like
    Default
    Yes in cans. I did a trailer, Plastic top carrier, and it stuck real nice. Made the top tougher. Try your local auto shops if not there try on line.
  6. #5
    Seasoned Member Dive Master's Avatar
    Join Date
    Jan 2006
    Location
    Western, KY
    Posts
    2,060
    Post Thanks / Like
    Default
    Quote Originally Posted by dandan
    Have never seen Rhino, there is a Hecules (I think) that is paint on.
    Rhino is expensive, and to be honest I do not know if moisture coming through the wood just might not make it let go. Could check with the dealer. I have it in my pick-up and love it.
    Donnie
    Illegitimi non carborundum.
    06 Titanium Wing (ABS)
  7. #6
    Seasoned Member NE-Jerry's Avatar
    Join Date
    Oct 2006
    Location
    Nebraska
    Posts
    141
    Post Thanks / Like
    Default
    Don't get any on your hands unless you want black hands for a few days. (Don't ask)
    Jerry Layman
    Fremont, NE
    Darksider #008
  8. #7
    Join Date
    Feb 2005
    Location
    Born in Maine. Living in exile, near Cape Cod, MA
    Posts
    1,210
    Post Thanks / Like
    Default
    Why not mix up a batch of fiberglas resin (no fiberglas, just the goop) and paint or roll that on?
    [SIGPIC
    George
    http://www.rkma3.org/
    http://www.redknightsmc.com/
    www.patriotguard.org
    _______________________________________
    There are two kinds of people. Those that do things, and those that take the credit. The trick is to be in the first group. There is far less competition.[SIGPIC]
  9. #8
    Join Date
    Jun 2007
    Location
    Central Texas
    Posts
    1,124
    Post Thanks / Like
    Default
    I haven't thought about that possibility.
    Wonder what the cost would be to cover 120 sf??
  10. #9
    Seasoned Member Bipeflier's Avatar
    Join Date
    Nov 2005
    Location
    Centralia, MO
    Posts
    1,167
    Post Thanks / Like
    Default
    An issue with epoxy is that if the wood floor can absorb moisture from the other side, it will expand and shrink depending on the moisture content. The epoxy will not. It will crack or flake off.
    '05 Candy Black Cherry
    '07 Aspen Classic
    Darksider 986
    2008 KLR 650 - 1969 T100R Triumph Daytona
    Centralia, MO
    VietNam Vet '70-'71 Da Nang Life Member VFW Post 6276
    '67 Suzuki, '37 Knuckhead, '74 TX500 Yamaha, '78 XS750 Yamaha, '82 Aspencade, '05 GL1800, a bunch of dirtbikes
  11. #10
    coolhand
    Guest
    Default
    We have been hauling bikes in trailers since the mid 70's. Mostly motocross but street bikes on rare occasions. There is always the temptation to make your trailer "pretty" and we have fallen into that mindset on a trailer or two. NEVER again.
    Advice from someone who has been doing this for decades. For the floor, forget pretty. Plain plywood is a great way to go. It's pretty much anti-skid, even when it's wet or when your boots are wet. You won't faint if you drop something heavy on it and you won't get pissed off at yourself or your buddy if you or he he accidentally scratches the hell out of it. From my experience plain plywood is far better than your pretty floor trailer, be it vinyl tile (with the BORING black and white checkerboard you see on the NASCAR wannabe guy's trailer), rino type sprays (stupid expensive), and paint/coatings of all and any type.
    In my humble opinion a pretty trailer floor is pretty stupid, from a practical and safety standpoint.
  12. #11
    Seasoned Member vptech2's Avatar
    Join Date
    Dec 2006
    Location
    Lake Charles, La.
    Posts
    297
    Post Thanks / Like
    Default
    I went to Lowes and got some rolled vinyl flooring. Cut it, rolled it out, put in a few staples and trim it with 1/4 round. Now I can sweep it and mop it when it gets muddy.
    Michelin Alpin PA3
    DSI #401
    http://www.murgie.com/dsi_roster.txt
    Members contact list
    GL1800Riders.com Contact List
  13. #12
    Join Date
    Mar 2005
    Location
    Booneville, Arkansas
    Posts
    447
    Post Thanks / Like
    Default
    I did an aluminum loading ramp to get my bike into shed a couple years ago with black paint and sand, had a 18" step to get into the shed and wanted some non skid on it. Just rolled on a thick layer of oil based paint and threw sand on top and repeated the process after it dried and excess sand removed.
    2008 Roadsmith Trike
    Battlax Bt 45 Front
    Aspen Classic Camper
  14. #13
    Join Date
    Jun 2005
    Location
    Henderson, NV(Hooterville)
    Posts
    340
    Post Thanks / Like
    Default Re: Best cost effective way to seal floor in a cargo trailer
    Lowes has floor paint with grit in it. Around $25 per gallon.
    That is what I'm gonna put on the floor and ramp of my 5 x 10 V nose trailer.
    Skip H
    03 1800ABS Candy Red
  15. #14
    Seasoned Member Crucible-Trike's Avatar
    Join Date
    Jul 2008
    Location
    Williamston, MI & Grand Island, FL
    Posts
    122
    Post Thanks / Like
    I had a new 6x10 Trailer built 2 years ago to haul my Trike in that had the floor done with a coating similar to Rhino coating. If you go to (http://www.classacttrailers.com) you can see how they are built. It will show you how strong they can be hit with a golf ball and not be dented. I believe all they build are cargo trailers and are great to deal with. I wanted mine with surge brakes and they said no problem. The floor being coated was a standard feature on there trailers, I'm sure if you contact them they could tell you what they use. I know I toured the small factory and it was done before the walls were installed. It's tought stuff, I have pushed furniture across it and not even scratched it. I have no connection with these people other than I bought my trailer from them and it's a great product.
    Donn
    Donn-MI
    07-Dark Orange-Level 2
    07-CSC
  16. #15
    Fire Eating Member
    Join Date
    Feb 2004
    Location
    U.S.A.
    Posts
    6,639
    Post Thanks / Like
    buy a gallon of Poly Varnish.... either roll it on or brush it on... it seals the wood against dirt, oil & moisture... usually 2 coats will do a nice job
    cosmic
    05 - CBC GL1800
  17. #16
    Join Date
    Sep 2005
    Location
    Riverside, CA
    Posts
    919
    Post Thanks / Like
    I did the vinyl flooring but it's slippery when wet. The sanded paint thing sounds good and while you can't sweep it as clean, it's as good as your garage floor (concrete).
    Darksider #141
  18. #17
    Seasoned Member IR Harry's Avatar
    Join Date
    Nov 2003
    Location
    On Work Release @ Soggy South Orygun Coast
    Posts
    9,433
    Post Thanks / Like
    Astro turf cut to fit?
    Happiness keeps you sweet, trials keep you strong, sorrows keep you human,
    failures keeps you humble, success keeps you glowing, but only God keeps you going
  19. #18
    Seasoned Member RareSS's Avatar
    Join Date
    Feb 2008
    Location
    Abilene, Texas
    Posts
    591
    Post Thanks / Like
    I guess that I am a "NASCAR Wannabe" and I am pretty "stupid", because both of my 26' Pace Daytona car haulers have the vinyl flooring in them..one is checkerboard and the other a marble look.
    The vinyl is slipperey to a point when wet, but it is really easy to mop and clean. I put the polished diamond plating down where the tires run and sit. Vinyl has a tendency to turn colors with the rubber tires sitting and running on them after a while.
    Void using Rhino liner on the ramps! When it is wet, it is very slipperey. My high torque Camaros and trucks tend to slide to one side or the other, when going up, if the ramp has gotten wet.
    Another thing you could do is put a sealer on the wood flooring and maybe stain it. It would be protected, look good, and still have a "some-what" of a non-slipperey surface.
    Jim
    The first known person to ride all 254 counties in Texas on a motorcycle!
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
