gl1800 whine and oil viscosity
+ Reply to Thread
Results 1 to 8 of 8
Thread: gl1800 whine and oil viscosity
  1. #1
    Join Date
    Jul 2004
    Location
    Ontario, Canada
    Posts
    896
    Post Thanks / Like
    Default gl1800 whine and oil viscosity
    ..couple of days ago, the weather was in the high '60's, low '70's and I
    noticed the enginewhine was really less noticeable
    ..few days before that, when the temp. was in the higher '70s and
    '80's, the engine whine, as with today, was more, more noticeable
    ..don't think this is my imagination as my wife mentioined that I've
    said this before
    ..anyone out with a "whine irritation,. decide to change to say,
    15W50 grade as it seems the thicker the oil, as with colder temperature,
    the less engiine whine.....if so, was there a difference
    ...if you look at Honda's recommended oil viscosity chart, it shows for
    temperatures from:
    - 10 to 90 degrees F to use 10w30
    - 10 to over 100 F to use 10w40.
    - 25 to over 100 F, to use either 15W40 or 15W50
    - 30 to over 100 F, to use either 20W40 or 20W50 is also fine
    ...it seems that for temperatures that range from 25 F to 80 and over,
    the usual warmer summer weather here, that 15W50 would be the i
    deal oil grade
    ...as the oil remains somewhat "thicker" in the colder weather and I hear
    less engine whine, it seems the 15W50 in the warmer temp's would give
    the same benefit?
    ...anyone out there with a somewhat "engine whine" irritation that has
    tried switching to a higher oil grade as 15W50 and if so, what difference
    was there, if any?
    thanks...Ken
    Kenner
    Illusion Red 2001
    " I intend to live forever. So far, so good "
  2. Advertisements
  3. #2
    Seasoned Member JohnACman's Avatar
    Join Date
    Jul 2007
    Location
    Orlando, Fla.
    Posts
    5,956
    Post Thanks / Like
    Default Re: gl1800 whine and oil viscosity
    I use 15/50 in my 06 for the past year. Mine whines in 5th gear. It quieted it down some but not all the way. BTW those temps you have there we only see in the winter down here.
    06, Dark Red GL1800
    Darksider #107
    Michlin Alpin 195/55/16 Run Flat (28psi) 5th one
    Bridgestone 701 bias ply front (36lbs)
    Rest in Peace, Beverly
    Florida Prowler #3
  4. #3
    Seasoned Member BACKDRAFT's Avatar
    Join Date
    Dec 2004
    Location
    Northwest Florida Panhandle
    Posts
    4,360
    Post Thanks / Like
    All 1800's whine due to the chains rather than the 1500's that used belts. Just the nature of the beast.
    I just turn my radio up louder and never notice the whine!
    Be sure to wave back!
    _________________________________
    Prowler 27
  5. #4
    IBTrike
    Guest
    The whine you are hearing is probably from the tranny due to straight cut gears (spur gears). They all do it. Heavier viscosity oil or cold oil will muffle it. There is also some whine from the alternator especially if it is under load. Cam chains to not whine.
    Harley trannys whine also....you just can't hear it over all the other racket.
  6. #5
    Join Date
    Sep 2007
    Location
    Southeast Ohio
    Posts
    162
    Post Thanks / Like
    I'm running 15W40 Rotella T and mine whines just like it always has. I had a 1300 VTX and it had its sounds and quirks so the whining in the GL1800 doesn't bother me any. Then again I don't hear worth a crap anymore.
    DUKE
    '07 GL1800 Black Metallic, Premium Sound, Comfort, Navi. (sold)
    '03 VTX1300S Durango Red (sold)
    Only a biker knows why a dog sticks its head out the window.
  7. #6
    Seasoned Member Waldo's Avatar
    Join Date
    Aug 2005
    Location
    NE Ohio
    Posts
    6,825
    Post Thanks / Like
    Just quit whining and ride!
    I use Mobile 1 15w50 and Advance auto parts ran a mobile 1 special a few months ago - 5 qts whatever syn you wanted (except bike) and a Mobil 1 filter for $26. I bought 4 specials and a WalMart SuperTech ST7317. I have five oil changes on the shelf for a little over $100 (hey, it ain't gonna get any cheaper!). Set for life I think since I change at about 13K or more with the extended perf Mobil.
    I use Mobile 1 in all my cars, trucks, lawn mowers, quads. 15W50 and I live in Ohio. Yes, this quad has 15w50 in it...
    KD8OVH
    '06 GL1800 Black Stealth F-117
    Progressive monotubes & Traxxion tree
    Vietnam Vet - Infantry Recon 69'-71'
    Daughter serves as LoadMaster CJ Elvis USAFr
  8. #7
    Join Date
    Jul 2004
    Location
    Ontario, Canada
    Posts
    896
    Post Thanks / Like
    ....just spoke with a local Honda parts person about the 15 or 20w50 oil,
    and he said that he knows of several 1800 riders who are using Golden Spectro
    semi-syn/petroleum 20w50
    ...the reasons given were 1) as the oil remains thicker, they've found
    the shifting is smoother and quieter and, 2) as the oil is thicker than the
    10/40, the engine runs cooler and the whine is quieter
    ....comments or is there anyone using this oil?
    Kenner
    Illusion Red 2001
  9. #8
    Seasoned Member Hal's Avatar
    Join Date
    Feb 2006
    Location
    Tyrone, GA
    Posts
    281
    Post Thanks / Like
    I am runnibg Amsoil 20W-50 during the summer months here in GA for the same reason. I do notice smoother shifts and a bit less noise over the Amsoil 10W-40 which I use the rest of the year.
    Hal
    IBA# 33407
    2006 Goldwing, Dark Red
    Previous Bikes:
    1996 1500 Goldwing
    1981 1100 Goldwing
    1975 1000 Goldwing
    1973 CB750
    1972 CB175
    Retired Air Force
    Download my GPS POI file of Honda MC Dealers with address and phone numbers. http://www.regi.net/poi/
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Where do you live?
Your rides, Bikes, Cars?
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
