Changing My Spark Plugs
+ Reply to Thread
Results 1 to 14 of 14
Thread: Changing My Spark Plugs
  1. #1
    Join Date
    Nov 2004
    Location
    Pennsylvania Dutch Country
    Posts
    117
    Post Thanks / Like
    Default Changing My Spark Plugs
    Hello,
    I am about to change my spark plugs on my 2003 Goldwing but don't know the correct procedure or gap setting. I have been searching the forums but not much luck. I know this has been covered but I apologize for not finding it. Can someone please help me with this? I would greatly appreciate it. Thanks in advance.
    John
    Can't we all just get along.....................
  2. Advertisements
  3. #2
    Seasoned Member IR Harry's Avatar
    Join Date
    Nov 2003
    Location
    On Work Release @ Soggy South Orygun Coast
    Posts
    9,433
    Post Thanks / Like
    Default
    Quote Originally Posted by cyclerider View Post
    Hello,
    John
    First, they come gapped. From Pg 3-8 of the manual,
    The OEM plug is BKR6E-11 (NGK),
    SPARK PLUG GAP: 1.0 1.1 mm (0.039 0.043 in)
    TORQUE: 18 Nm (1.8 kgfm, 13 lbfft)
    Happiness keeps you sweet, trials keep you strong, sorrows keep you human,
    failures keeps you humble, success keeps you glowing, but only God keeps you going
  4. #3
    Join Date
    Jan 2008
    Location
    East Alton, IL
    Posts
    465
    Post Thanks / Like
    Default
    The procedure is the same for any spark plug. Check the gap with a feeler gauge and if it's not .039 to .043 adjust the gap. You will most likely find that they are gapped correctly when you get them out of the box.
    The person who dies with the most toys... WINS!
    01 GL1800 Ill. Red
    85 GL1200 Aspencade
    84 GL1200 STD
  5. #4
    Seasoned Member upssnowman's Avatar
    Join Date
    Oct 2004
    Location
    Sparta, Tn.
    Posts
    2,360
    Post Thanks / Like
    Default
    I buy mine at Napa $2.09 a piece
    BKR6E-11 (NGK)
    only remove from COLD engine
    torque properly gap .41
    clean drain tube while your there, left side-front
    Do it all now you may not be able to do it Later
  6. #5
    Join Date
    Nov 2004
    Location
    Posts
    117
    Post Thanks / Like
    Default
    Guys,
    Thanks for the plug information. One other small thing? How do you get to the plugs to change them? Thanks again.
    John
  7. #6
    Seasoned Member sammisgrammy's Avatar
    Join Date
    Aug 2005
    Location
    Ellwood City, Pa
    Posts
    4,445
    Post Thanks / Like
    Default
    Guys,
    John
    You have to remove the side covers, by removing the 2 bolts in the center, and the 3 on the bottom. Then you'll see the plugs and can change them out. (There are little plastic plugs in the bolt heads that have to be removed before the hex will fit).
    My plugs out of the box were off alittle and I used a free plug tool from AutoZone to get them all to match. Good luck, it's an easy job that takes very little time. Some guys blow the dirt away from the plugs before removal, which is probably a good idea, and if you are into torqueing, they torque at 13 lbf-ft.
    Good luck! If you need any info from the manual shoot me a PM
    '05 CBC
  8. #7
    Seasoned Member copilot's Avatar
    Join Date
    Apr 2008
    Location
    Lincoln, NE
    Posts
    731
    Post Thanks / Like
    Default
    Also, might not be a bad idea to put some anti-sieze(sp?) on the threads of the new ones.
    2004 Suzuki Volusia
    2008 Goldwing
    Yokohama Envigor run flat
    Pirelli euforia run flat
    AMERICAN LEGION RIDER
  9. #8
    Join Date
    Jul 2007
    Location
    Northeast Ohio
    Posts
    306
    Post Thanks / Like
    Default
    One additional note...
    Last fall when I was winterizing the GL1800, I was using the POS spark plug socket from the GL1800 toolkit rather than digging in my tool chest for a better socket. Well, I ended up cracking the ceramic body of one of the plugs.
    It was a Sunday afternoon, and not many parts stores open. The only place I could find that had the plugs carried the BRK6E not the BRK6E-11. A quick look on the NGK site shows that the "dash" number is the gap (-11 for 1.1 mm). If there is NO "dash" number, then the gap is .8mm. That is the only difference between the two.
    So, I bought the BRK6E re-gapped them to 1.0-1.1mm and all is fine.
    Just wanted to toss in another data point in case the parts store hands you plugs that are labeled as BRK6E with no "dash" number.
    Thanks,
    08, Bright Red Metallic, ABS GL1800
  10. #9
    Seasoned Member OrangeCrush's Avatar
    Join Date
    Nov 2003
    Location
    Mena, AR
    Posts
    5,369
    Post Thanks / Like
    Default
    one additional "final" point ... be darned careful in torquing the bolts when you put the covers back on. I wasn't and ended up breaking the raised connection "nut" -- that aluminm is BRITTLE !!!
    Peter Dahl Mena, Arkansas
    '03 ABS Red FSC600 Silverwing
    '04 Orange VTX1800C
    '04 CBC Rune
    '06 KLX300R
    '09 ABS CBC GL1800
    Learn like you're going to live forever; Live like you're going to die tomorrow
  11. #10
    Join Date
    Nov 2004
    Location
    Posts
    117
    Post Thanks / Like
    Default
    Guys,
    Thanks so much for that information. I am now ready to do some work. I appreciate everyone's valuable comments. I checked with the local Honda Dealer and they want $80 for labor and $12 a plug. Now that is ROBBERY!!
    John
  12. #11
    Join Date
    Aug 2005
    Location
    Ellwood City, Pa
    Posts
    4,445
    Post Thanks / Like
    Default
    Guys,
    John
    YES IT IS!! It will take you less than an hour and cost under $20-big savings!
    '05 CBC
  13. #12
    Join Date
    Oct 2004
    Location
    Sparta, Tn.
    Posts
    2,360
    Post Thanks / Like
    Default
    the 5 bolts each side just go back snug and put the little rubber dealies back to keep out dirt I use a dental pick to get them out
  14. #13
    Seasoned Member BigMick's Avatar
    Join Date
    Aug 2007
    Location
    Midwest
    Posts
    1,704
    Post Thanks / Like
    Default
    You have a PM.
    2007 Lehman Monarch II
    One day at a time works fine for me!
  15. #14
    Join Date
    Nov 2004
    Location
    Posts
    117
    Post Thanks / Like
    Default
    Thanks Guys,
    Changed the plugs this weekend. Easier than I thought. Again, thanks to everyone that posted for me.
    John
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Where do you live?
Your rides, Bikes, Cars?
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
