How do I wire trailer side marker lights to flash?
+ Reply to Thread
Results 1 to 2 of 2
Thread: How do I wire trailer side marker lights to flash?
  1. #1
    Seasoned Member csshafer's Avatar
    Join Date
    Mar 2007
    Location
    Houston, TX
    Posts
    495
    Post Thanks / Like
    Default How do I wire trailer side marker lights to flash?
    Here's what I want to do...
    I want to install LED sidemarker lights (amber) on each side of my trailer. I've decided on the rectangular reflectors/sidemarker lights from Show Chrome that have 15 LED lights in them. The problem is, they only have 2 wires. This is easy as long as I just want sidemarkers. However, I'd like to wire them where they're sidemarkers until I turn on the turn signals and then I'd like them to flash alternately from the bike and trailer turn signals like most cars do.
    I think if I run a wire from my trailer TS feed to the ground of the new sidemarker lights then they will go off when they get a hot feed from the TS wire. Is this right? Also, would I need to install a diode to keep power from backfeeding into the entire ground system.
    Am I off base here and is there an easier way to get a sidemarker/TS combination with only a 2-wire light?
    Thanks in advance,
    2008 Black GL1800 ABS
    1995 Bushtec Turbo+2
  2. Advertisements
  3. #2
    Seasoned Member Wanderer's Avatar
    Join Date
    Jun 2004
    Location
    Peoria
    Posts
    2,559
    Post Thanks / Like
    Default
    Why not get 3 wire lights? I found these on ebay with a quick search: http://cgi.ebay.com/ebaymotors/Amber...QQcmdZViewItem
    There's probably more out there if you look around.
    Keep On Tourin'
    The Wanderer
    2005 Pearl Yellow GL1800A / 2005 Pearl Blue 1940 Ford
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
