Need some help.
After replacing the rear shock absorber and actuator with a new one, I adjusted it up once then got a Sus Adj Error on the LCD when I tried to adjust it again. I've checked fuse #28 and switched relays both seem fine. Double cheched wire connections and all is good. Is there anything else I can check or do to get working again.
. Thanks again.
