Satellite Radio and Booster Antenna Installed??
+ Reply to Thread
Results 1 to 11 of 11
Thread: Satellite Radio and Booster Antenna Installed??
  1. #1
    Seasoned Member Vtxryder's Avatar
    Join Date
    Sep 2008
    Location
    Lynden, WA - Now in Sunny AZ
    Posts
    218
    Post Thanks / Like
    Default Satellite Radio and Booster Antenna Installed??
    Question; For those of you that installed a satellite radio - did you use the or rather hook up the FM Extender Antenna that came with the vehicle kit; it goes as close to the rear bike antenna as possible?? and plugs into the back of the docking station.
    What do you think - does it make any difference???
    Thanks - just installing it now.
  2. Advertisements
  3. #2
    Seasoned Member joliveto's Avatar
    Join Date
    Jul 2009
    Location
    West Virginia
    Posts
    239
    Post Thanks / Like
    Default
    I used the regular antenna and ran it to the back of the passenger seat. I cut a small piece of Velcro and attached it that way. it sits right in the center at the back. works great
    Darksider #661
    2008 Goldwing ABS
  4. #3
    Join Date
    Aug 2009
    Location
    not here
    Posts
    334
    Post Thanks / Like
    Default
    I don't use the antenna extender but I do have the satellite radio plugged into the AUX plug. Much better than running it through the FM.
  5. #4
    Join Date
    Aug 2006
    Location
    B.A. Okla
    Posts
    800
    Post Thanks / Like
    Default
    Nope, I have the Hockey puck that goes to the Zumo 550 on mine. Purchased a bracket that mount right to the handle bar for both.
    My GPS says "Estimated Arrival Time." I see "Time to Beat."
    Jerry
    '06 Dark Red Wing, '02 Burple VTX-R
    PGR Member #168
    South Central
    Regional Ride Captain
    OK-TX-AR-MO-KS
    IBA# 28658
    US Army Airborne '74/'77
  6. #5
    Join Date
    Sep 2008
    Location
    Posts
    218
    Post Thanks / Like
    Default
    Thanks Guys -- Two additional questions for;
    Jolivito -- your talking about the antenna that came with the car kit I assume, mounting it to just behind the seat back -- that's what I thought I'd do -- glad to hear that works.
    bpd221 -- by using the aux plug I heard that the volume can be really reduced compared to using the FM radio -- you find that???
    Thanks Again ... Paul
  7. #6
    Seasoned Member SLOWDOG's Avatar
    Join Date
    Jun 2008
    Location
    Arlington, Virginia
    Posts
    1,928
    Post Thanks / Like
    Default
    Many XM radios have an line output adjuster. I adjusted my Roady XT until the output from the aux matched up pretty closely with the FM levels.
    "SLOWDOG"
    07 Goldwing - Comfort/Navi/ABS Dark Blue Metallic
    Traxxion "Maximum Monty" with Billet Triple Clamps
    My road trip slogan: "I fear the deer."
  8. #7
    Join Date
    Sep 2008
    Location
    Posts
    218
    Post Thanks / Like
    Default
    Thanks Slowdog -- probably find that in the menu of the radio???
  9. #8
    Join Date
    Aug 2009
    Location
    not here
    Posts
    334
    Post Thanks / Like
    Default
    Quote Originally Posted by Vtxryder View Post
    No, I find it the other way around, it is louder with the plug. Plus no FM interference.
    either way it is great to not HAVE to change or look for stations for miles and miles.
  10. #9
    Join Date
    Sep 2008
    Location
    Posts
    218
    Post Thanks / Like
    Default
    Excellent Thanks bpd221 that sounds like the way to go - my cig. lighter connector should arrive today, the rest is here and I'll have it up and running by the end of the day -- looking forward to - as you said -- miles and miles of tunes!!
    Thanks everyone for your ideas and advise!!!
  11. #10
    Join Date
    Jul 2009
    Location
    West Virginia
    Posts
    239
    Post Thanks / Like
    Default
    yep works like a charm.. although that fancy cone ant. looks cool
    also I got that complete setup http://www.electricalconnection.com/...18-ipod-hb.htm
    I have a inno so I don't have to worry about an fm modulator, it's built into the radio. sound is great, I gave My wife the remote so every now and then she'll switch channels from the back seat. good luck
    here's the right web page... sorry...
    http://www.electricalconnection.com/audio/03122.htm
    Last edited by joliveto; 11-13-2009 at 11:12 PM. Reason: just thought of something else
    Darksider #661
    2008 Goldwing ABS
  12. #11
    Join Date
    Sep 2008
    Location
    Posts
    218
    Post Thanks / Like
    Default
    Thanks Guys ... appreciate the advise ...
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Where do you live?
Your rides, Bikes, Cars?
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
