Radial tires
+ Reply to Thread
Results 1 to 6 of 6
Thread: Radial tires
  1. #1
    Seasoned Member rrscott's Avatar
    Join Date
    Nov 2007
    Location
    Maquoketa, Iowa
    Posts
    793
    Post Thanks / Like
    Default Radial tires
    I'm getting a used Bunkhouse, It has 4.80-12 tires. Can you put radial tires(145R12) on the same rims? And are they better?
    RANDY
    2003 Goldwing/2010 Motortrike Adventure
  2. Advertisements
  3. #2
    Seasoned Member IR Harry's Avatar
    Join Date
    Nov 2003
    Location
    On Work Release @ Soggy South Orygun Coast
    Posts
    9,433
    Post Thanks / Like
    Default
    I put 155 SR 12 tires on my Bunkhouse, and they work just great. That was 5 years ago, and the friend that has it now still is using the same tires, not even showing signs of wear, and he has pulled it over 15,000 miles. They just keep running...and running.....and running.....
    and my current Rollahome has them also.
    Happiness keeps you sweet, trials keep you strong, sorrows keep you human,
    failures keeps you humble, success keeps you glowing, but only God keeps you going
  4. #3
    Seasoned Member Grandpa 913's Avatar
    Join Date
    Jan 2008
    Location
    Morganton, North Carolina
    Posts
    396
    Post Thanks / Like
    Default Radials
    What Harry said +! I put radials on my last Bunkhouse and pulled it about 20,000 miles, sold it to a friend last year and he has towed it all summer, and tread on those tires looks like new. I purchased a set of 155X12 tires that were made for old Honda Civics that fit the rims just fine and were very easy to balance. They were a little large for the opening in the fenders, so I had to open up the radius of them. My new Bunkhouse has radials on it from factory, I think they are 145Rx12. I sure like the way the camper rides with radials verses Bias ply tires, Lots smother over bumps
    By the way Congrats on the Camper purchase check out the IBMC at
    www.ibmc.org
    Great People and lots of fun motorcycle camping
    Grandpa
    Past Master Sunrise #783
    DarkSide # 1404
    2003 GoldWing, Current
    2010 Bunkhouse
    1996 Kompact-Kamp
    1995 Bunkhouse
    1996 Bunkhouse
    1996 Kwik-Kamp
    1989 Kompact-Kamp
    2000 Kompact-Kamp
    1998 Bunkhouse
    2004 Bunkhouse
    Motorcycles and camping just go together!
    Member IBMC
    Patriot Guard
  5. #4
    Join Date
    Nov 2007
    Location
    Maquoketa, Iowa
    Posts
    793
    Post Thanks / Like
    Default
    What air pressure are you using in both 4.80's and radials?
    RANDY
  6. #5
    Join Date
    Jan 2008
    Location
    Posts
    396
    Post Thanks / Like
    Default
    Quote Originally Posted by rrscott View Post
    Some call for 50 psi, that is what they told me at Bunkhouse when I picked up my new camper with radials on it, I ran at least 35 or more in the 155X12 tires is seemed to tow easier
    DarkSide # 1404
    2010 Bunkhouse
    1996 Kompact-Kamp
    1995 Bunkhouse
    1996 Bunkhouse
    1996 Kwik-Kamp
    1989 Kompact-Kamp
    2000 Kompact-Kamp
    1998 Bunkhouse
    2004 Bunkhouse
    Member IBMC
    Patriot Guard
  7. #6
    Join Date
    Nov 2007
    Location
    Maquoketa, Iowa
    Posts
    793
    Post Thanks / Like
    Default
    Thank you!
    RANDY
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
