Polishing your Brake Pedal - Amazing Results! - A How To Guide
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 30 of 45
Thread: Polishing your Brake Pedal - Amazing Results! - A How To Guide
  1. #1
    Seasoned Member daveo's Avatar
    Join Date
    Apr 2008
    Location
    Central Texas
    Posts
    2,133
    Post Thanks / Like
    Default Polishing your Brake Pedal - Amazing Results! - A How To Guide
    In another thread here I asked if anyone had any pointers / tips on polishing their brake pedal. I promised to provide a how-to guide with pictures when I finished mine. So here you go:
    Materials Used.
    Source: Walmart Automotive Department
    1. 1 Pack of 1000 grit wet/dry sandpaper (used 2 sheets)
    2. 1 Pack of 2000 grit wet/dry sandpaper (used 1 sheet)
    3. 1 can of Mothers Wheel Polish for Aluminum Wheels (just used a few dabs on a paper towel for polishing)
    Tools used:
    1. Bench vise to hold the pedal while filing and sanding on it.
    2. Red Shop Rag ( to keep from nicking the pedal while clamped in the vice)
    3. Some fine mill files small and a medium size.
    4. Scissors for cutting the sandpaper into strips.
    1. I got a used brake pedal off ebay for a few dollars so I could spend all the time I needed to get the job right. It was worth it as I still have my original pedal in case I ever want to return the bike back to stock. (like thats ever going to happen )
    2. Placed the red rag so as to insulate the jaws of the vice from the pedal, I positioned the pedal to begin the seam removal. The pedal is cast from aluminum and the mold seam is clearly visible on the sides. When you polish the pedal, it looks a whole lot better if you remove the seam first.
    Here is a picture of the seam removal process. I used a fine mill file to work this part. one direction strokes, and try to keep it flat so the file doesn't chatter the metal.
    Keep working with the file till you wear down the seam and it blends in with the sides of the pedal arm.
    When you've gotten the seam removed, it's time to start with the sanding. Cut a long strip off your 1000 grit sheet of wet/dry paper and start working it back and forth holding one end in each hand, like you were polishing a pair of shoes. Work up and down, back and forth to get the three exposed sides of the pedal arm. You will be generating alot of aluminum dust. The 1000 grit will bite and remove some of the surface imperfections along the seam area. This make take a while, and use multiple strips of the 1000 grit paper. I also went around the pinch bolt (clamp area) with the 1000 grit paper by using my fingers to get into the irregular shapes. The idea is to smooth out the pedal arm as much as possible of any bumps or irregularities.
    This picture shows most of the seam smoothed away after sanding with the 1000 grit paper.
    Keep at it with the 1000 grit paper. You will use quite a few strips to do the whole arm. It's easier to use the 1000 grit now and then follow up with the 2000 grit later to get that final smoothness that will polish up.
    Remember to evenly sand every bit of the pedal arm that will be visible when installed on the bike, I did 3 sides including the bottom and clamp area. Probably overkill.
    After sanding, you can see that the arm is almost perfectly smooth and the seam is gone.
    After you have gone over the arm with the 1000 grit follow over it again with the 2000 grit. That will tend to remove any of the surface marks that the filing or the 1000 grit sanding caused. You will be pretty amazed at how much dust the 2000 grit generates and the overall smoothness it creates. This step is crucial to getting a smooth, even shine.
    Now you are ready for Mothers! I used a high fiber paper towel, but the blue shop towels or a red shop rag would work just as well. It's time to put on the mothers mag wheel polish. Dab a little on your towel and rub like your polishing your shoes. Same principle anyway.
    You are going to go over and go over the pedal arm getting the compound into every area of the pedal you want to shine. I choose to leave the grooved / foot area natural so I didn't mother's that portion but I did the rest of the pedal multiple times.
    One thing I did, that I didn't get a picture of was after I polished it, I hit it again with the 2000 grit strips. This got the last bit of evidence of the seam and smoothed out the last ruff spots. Then I hit it with the polish for the final time.
    The final application of Mothers polish.
    The final results
    Ready for a shot of clear coat with lacquer.
    This is the backside, the side that faces towards the lower side cowling.
    Awesome! I'd do it again without hesitation. Well worth the effort in my opinion.
    Good Luck on polishing your pedal!
  2. Advertisements
  3. #2
    Seasoned Member Joe In Calif's Avatar
    Join Date
    Jun 2004
    Location
    San Jacinto, Calif.
    Posts
    4,957
    Post Thanks / Like
    Default
    Looks like a lot of work but it looks great, I bought a chrome after market one, I guess I'm just lazy.
    DSCN0581
    If you are born once you wil die twice.
    If you are born twice you will die once
    RETIRED AND LOVING IT !!
  4. #3
    Seasoned Member TDI's Avatar
    Join Date
    Aug 2008
    Location
    Kathleen, GA
    Posts
    383
    Post Thanks / Like
    Default
    Pretty snazzy looking. How much time you think it took you? I may have to get an extra one to play with, that looks goooooood!
    Jay
    08 - GL1800
    84 - XL125S
  5. #4
    Join Date
    Apr 2008
    Location
    Central Texas
    Posts
    2,133
    Post Thanks / Like
    Default
    It took a couple of hours on a rainy day in the garage. I probably wouldn't have done it if I didn't have a spare pedal and lousy riding weather though.
    Help Save America - Please Vote
  6. #5
    Seasoned Member zg1286's Avatar
    Join Date
    Jan 2006
    Location
    Jackson Center Oh
    Posts
    1,450
    Post Thanks / Like
    Default
    I have tried every aluminum polish out there. Boms Away is good. Bushs to me takes to much work. I always go back to MOTHERS. Been using it for 30+ years now.
    I am not totally useless I can always serve as a BAD EXAMPLE
    "If dogs don't go to heaven, when I die I want to go wherever they went."
    2002 Stream Silver
    Member of The Backroom Executives Motorcycle Club
    Proud Member of The Patriot Guard Riders
    AMA CHARTER LIFE MEMBER #344314
    LIMNCS Member # 1286
    Retired Motorcycle Parts Manager 25 years
    Parts Manager Rising Sun Express. The parts were a lot lighter in the Motorcycle Biz
  7. #6
    Join Date
    Nov 2003
    Location
    Independence Ohio
    Posts
    17,908
    Post Thanks / Like
    Default
    Very nice work.
    Now that's my kind of customizing. You must have been a hot rodder back in the 60s or 70s. Those were the days of real customizing, where your ride was the result of a lot of sweat, bruised knuckles, and dirt under your fingernails.
    We need to see more of that here, not the instant gratification of stick on, chrome plated plastic.
    Larry
    2002 Illusion Blue GL1800
  8. #7
    Join Date
    Jan 2005
    Location
    Fayetteville, NC
    Posts
    340
    Post Thanks / Like
    Default
    That is exactly like I suggested in my earlier post. EXCEPT! It makes the job much faster if you use wet or dry sand paper and sand it under a trickle of water from a faucet. It took me maybe an hour or less to do mine. I start the sanding with a piece of 320 wet or dry and then 1000 and next 2000. The water will let the sand paper cut faster and not fill up the paper with aluminum crud. Good Job!
    Give me a crooked road and a good handling bike.
  9. #8
    Join Date
    Apr 2008
    Location
    Central Texas
    Posts
    2,133
    Post Thanks / Like
    Default
    Thanks for the complements. The time factor isn't all that long, it looks like a more involved process because of my instructions than it actually is. I got a surplus pedal to work on for two reasons. 1. I could still ride my bike while I worked on the spare pedal. 2. If i messed it up, my original pedal was still on my bike and the spare could have been tossed. Of course, using Mothers, makes it hard to mess up
    Here is a picture off ebay of a polished pedal for sale by a dealer for around $60 with shipping. They didn't remove the seam. To the right is my pedal for comparison. I think it was time well spent.
  10. #9
    Seasoned Member Pigeon Roost's Avatar
    Join Date
    Jan 2004
    Location
    Logan, WV
    Posts
    12,698
    Post Thanks / Like
    Default
    Shure is purdy, but, does it stop any faster?
    2002 Black Standard Brakes "TE MEGA MONTY"
    DARKSIDER #1249
    "Well, Chester; choos'n friends goes kinda fast once the shoot'n starts." Mathew Dillon to Chester Goode
  11. #10
    Seasoned Member Bobalou's Avatar
    Join Date
    Aug 2008
    Location
    Richmond, Kentucky
    Posts
    859
    Post Thanks / Like
    Default
    OK, I give up...mine is too scratched up from the road while leaning too much. I also gave up bike shows when the second closet got to full.
    Now go ride!
  12. #11
    Join Date
    Aug 2004
    Location
    Centerville Ohio
    Posts
    1,764
    Post Thanks / Like
    Default
    Painted mine Black to match all my other plastic parts.
    Bob
    2011 Ultra Electra Glide Limited (BLACK)
    08 Blackwing
    03 Blackwing
  13. #12
    Join Date
    Apr 2008
    Location
    Central Texas
    Posts
    2,133
    Post Thanks / Like
    Default
    Quote Originally Posted by Pigeon Roost View Post
    Sure does. By removing the seam, it cut down on the overall weight of the bike, and it improved the gas mileage too. It's so slippery now, it just slices through the air.
  14. #13
    Join Date
    Jan 2004
    Location
    Logan, WV
    Posts
    12,698
    Post Thanks / Like
    Default
    The way fuel has shot up in the past week or two, you may have a significant savings there.
    DARKSIDER #1249
  15. #14
    Join Date
    Jan 2005
    Location
    SW PA
    Posts
    1,968
    Post Thanks / Like
    Default
    When I read this post earlier I thought it sounded like a silly idea. Today I put a coat of wax on the wing and was looking at the brake pedal and well I'm going to do it too. Good rainy day project.
  16. #15
    Join Date
    Nov 2003
    Location
    Independence Ohio
    Posts
    17,908
    Post Thanks / Like
    Default
    Quote Originally Posted by ponton View Post
    I just have to decide if I have enough of that 18 year old left in me to care about what the brake pedal looks like. These days, as long as it is clean and runs good, I'm happy.
    If I don't have a lot of maintenance to do on the bike this winter, I will probably do it.
    Larry
  17. #16
    Seasoned Member cgent's Avatar
    Join Date
    Mar 2006
    Location
    Winchester, Indiana
    Posts
    1,754
    Post Thanks / Like
    Default
    You've probably voided your warranty ...
    ... and the oil will leak out ... and the front wheel will wobble ...
    Tom Batt ... the "FROGG TOGGS GUY"
  18. #17
    Join Date
    Mar 2006
    Location
    Winchester, Indiana
    Posts
    1,754
    Post Thanks / Like
    Default
    ... almost forgot ... LOOKS GREAT ... .
  19. #18
    Seasoned Member GRWilson's Avatar
    Join Date
    Mar 2009
    Location
    Newburgh, IN
    Posts
    352
    Post Thanks / Like
    Default
    Nice job and it looks great. Thanks for sharing.
    Willie Wilson WD9FHA
    Newburgh, IN
    MARC
    GWRRA
    IBA #22660
    DSI #429
  20. #19
    Seasoned Member MG_Wings's Avatar
    Join Date
    Jul 2006
    Location
    Tacoma, Wa.
    Posts
    773
    Post Thanks / Like
    Default
    Looks great!
    2006 White 1800GL
    2006 Pearl White Escapade SE trailer
    PGR member
    http://www.patriotguard.org/
    The "Black Pirate" has left us a message. Did you get it?
  21. #20
    Seasoned Member doszer's Avatar
    Join Date
    Feb 2008
    Location
    Fort Washington, Md.
    Posts
    586
    Post Thanks / Like
    Default
    Very nice job. Good way to kill time.
  22. #21
    Seasoned Member roadlizard's Avatar
    Join Date
    May 2009
    Location
    Corpus Christi,Tx
    Posts
    459
    Post Thanks / Like
    Default
    Fantastic...worth the extra effort.
    2006 Cabernet Red
  23. #22
    Join Date
    Feb 2006
    Location
    East Tennessee
    Posts
    157
    Post Thanks / Like
    Default
    I'd rather be riding.
    Motodoc42
  24. #23
    Seasoned Member CAWing's Avatar
    Join Date
    Nov 2003
    Location
    Sanger, CA
    Posts
    5,221
    Post Thanks / Like
    Default
    Quote Originally Posted by daveo View Post
    And as an added bonus he doesn't have to use a crush washer on the oil drain plug anymore. Nice work
    Paul... Vietnam Vet, 65/66/67, We're not here for a long time, just a good time!, '04 Durango Red 47,750 smiles, '01 Illusion Red, 167,500 smiles-Sold 01/27/2011, Kwik Kamp Trailer, Patriot Guard Rider,
    Central CA.
  25. #24
    Join Date
    Dec 2006
    Location
    New Jersey
    Posts
    1,114
    Post Thanks / Like
    Default
    I had the boards on my Aero 1100 polished. I really liked the way polished metal looks - it is different than chrome.
    Very nice.
    Hector
    2003 ABS Durango Red Metallic
    New Frame
    Traxxion - "Old" Fully Monty
  26. #25
    Seasoned Member dirtdobber's Avatar
    Join Date
    Mar 2010
    Location
    north Alabama
    Posts
    828
    Post Thanks / Like
    Default
    Looks good.
    If I ever get the time I will need to do this but I am lazy so I will use my bench polisher.
    good job
    dd
  27. #26
    Member
    Join Date
    Dec 2008
    Location
    Tucson,AZ
    Posts
    9
    Post Thanks / Like
    Default Wow!!!
    You must be retired.
  28. #27
    Seasoned Member Jchefboyardee's Avatar
    Join Date
    Mar 2006
    Location
    Texas, New Boston
    Posts
    6,962
    Post Thanks / Like
    Default
    I'm thinking about doing that to my crush washers too! Looks nice....
  29. #28
    Seasoned Member upssnowman's Avatar
    Join Date
    Oct 2004
    Location
    Sparta, Tn.
    Posts
    2,358
    Post Thanks / Like
    Default
    very nice , good job
    reminds me of polishing aluminum on my old '69 BSA lightning 650 with Simichrome, used to get it like chrome
    Do it all now you may not be able to do it Later
  30. #29
    Seasoned Member aphillipsiii's Avatar
    Join Date
    Oct 2006
    Location
    Hoschton, GA
    Posts
    817
    Post Thanks / Like
    Default
    Very nice job.
  31. #30
    Veteran Member wingwing's Avatar
    Join Date
    Nov 2006
    Location
    Fla. WW~MM
    Posts
    11,104
    Post Thanks / Like
    Default
    WOW ... that looks sweet!
    (it looks WAY better than the KuryCrappin junk).
    Thank you for taking the time to post pictures
    and step by step "how to" instructions..
    There are still MANY of us that do appreciate
    the effort and time it takes to
    document and share that kind of information.
    thanks again,
    Dennis
    Life..DS#99/Prowler#0
    ♪'You may say that I'm a dreamer, but I'm not the only one'♪~ J.L.
    All truth is at first ridiculed, then opposed, and finally, self-evident.
    'Since the house is on fire, let us warm ourselves' ~ old Italian proverb
    ...Ride Safe, Avoid R.U.D...
    Psychopaths not welcome here.
    You know who you are.
    Find another sandbox to play in.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Where do you live?
Your rides, Bikes, Cars?
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
