Turn Signal
+ Reply to Thread
Results 1 to 8 of 8
Thread: Turn Signal
  1. #1
    Seasoned Member Jack M's Avatar
    Join Date
    Aug 2008
    Location
    Roy, Utah
    Posts
    137
    Post Thanks / Like
    Default Turn Signal
    Were is the turn signal relay on a 1800 located. And how do you get to it?
    Jack & Helen Goddard
    Roy, Utah
    2005 Blue 1800 CSC Trike
  2. Advertisements
  3. #2
    Seasoned Member IR Harry's Avatar
    Join Date
    Nov 2003
    Location
    On Work Release @ Soggy South Orygun Coast
    Posts
    9,433
    Post Thanks / Like
    Default
    There is a relay in the turn signals? Or is it just a flasher unit?
    Happiness keeps you sweet, trials keep you strong, sorrows keep you human,
    failures keeps you humble, success keeps you glowing, but only God keeps you going
  4. #3
    Join Date
    Aug 2008
    Location
    Roy, Utah
    Posts
    137
    Post Thanks / Like
    Default
    Not sure. When you turn the signal switch either way. Right and left signal lights Both at the same time come on on the dash, same thing happens when you put on the brake. Check all the bulbs. Front signals come on ok. Was using the emergency flasher yesterday for about 15 munutes. Parked it and got cought in heavy rain. It started acting up when I started it up after that. Acts like the Emergency switch is on all the time but It turns off.
    Roy, Utah
  5. #4
    Seasoned Member Mark Rowell's Avatar
    Join Date
    Sep 2004
    Location
    Roseburg, OR
    Posts
    2,091
    Post Thanks / Like
    Default
    I am not sure what you are looking for, but you should look at a Honda Electrical Troubleshooting Manual to run this down. I looked at my ETM and found the following:
    The "tail relay" is located under the seat just behind the fuel tank sensors (ETM pg 12-6 photo 38. It is the center relay. It supplies power to all the tail lights when the ignition switch is turned on.
    The "turn signal relay" is located behind the instrument cluster (ETM pg 12-12 photo 74). I am not sure but I think this is the one that causes the turn signals to blink on and off.
    I can't imagine troubleshooting electrical problems without using an ETM. Hope this helps.
    Former MSF/CMSP instructor, IBA#6027
    2005 GL-1800A, Metalic Silver
    Retired in Roseburg, OR
  6. #5
    Join Date
    Oct 2004
    Location
    Bakersfield, CA
    Posts
    583
    Post Thanks / Like
    Default
    I would start at the emergency flasher switch. take it loose and make sure none of it is still engaged. The brake light part has me confused since the blinkers and the brake lights are not part of the same system like a Ford pickup, (just an example of a shared blinker and brake light system). The brake lights should never cause the turn signal indicator lights on the dash to light up.
    2003 non-ABS
    Ex-Darksider
  7. #6
    Seasoned Member Lee H. Mann's Avatar
    Join Date
    Jun 2010
    Location
    Martinsburg, WV
    Posts
    191
    Post Thanks / Like
    Default
    Quote Originally Posted by Jack M View Post
    By any chance do you have a hitch with an adapter for your trailer wiring ?
    "If my computer is so smart, why doesn't it know my limitations ?"
  8. #7
    Join Date
    Aug 2008
    Location
    Roy, Utah
    Posts
    137
    Post Thanks / Like
    Default Lights
    Yes I do have wires for a trailer. I took the cover off they look ok. Maybe a place to start with a meter. Thanks. I took the emg flasher switch out and it was clean and dry.
    Roy, Utah
  9. #8
    Join Date
    Jun 2007
    Location
    Elsewhere
    Posts
    11,202
    Post Thanks / Like
    Default
    If your trailer wiring isolator and/or converter came from Electrical Connections you may want to give them a call. They were having issues with some of those parts fail. That is what I have on my bike and I had to replace one of the two pieces but can't remember which (I am thinking it was the converter). However, when mine failed I had different symptoms than what you have explained.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Where do you live?
Your rides, Bikes, Cars?
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
