Solid axel vs. Independent suspension
+ Reply to Thread
Results 1 to 16 of 16
Thread: Solid axel vs. Independent suspension
  1. #1
    Seasoned Member wobray's Avatar
    Join Date
    Nov 2003
    Location
    Skipperville, AL (LA)
    Posts
    121
    Post Thanks / Like
    Default Solid axle vs. Independent suspension
    I am especially interested in Motor trike's units. Is there really a lot of difference in these two different set ups? I will trike my 07 this year or next.
    TIG
    Bill Bray (Morpheus)
  2. Advertisements
  3. #2
    Seasoned Member trike lady 1500's Avatar
    Join Date
    May 2010
    Location
    Ormond Beach, Florida
    Posts
    2,005
    Post Thanks / Like
    Default
    Below are images of a solid axle from Lehman and an independent suspension from Motortrike. A picture is worth a thousand words, but take a test ride on each trike and see which you like best. Both ride well, most of the people I know do a lot of trailer towing and have the solid axle. You may prefer the more responsive handling of the independent suspension, it's really what you feel more comfortable with handling wise. A test ride is very important before you buy.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	21491   Click image for larger version.
    The busy beaver said, "I have one Dam job after another". Prowler# 11
  4. #3
    Join Date
    Dec 2005
    Location
    no need to know
    Posts
    1,052
    Post Thanks / Like
    Default
    I have had the older MT with ladder bar suspension and it rides surprisingly well compared to most solid axle units. I now have the new MT IRS and there is a remarkable difference in the ride and handling. I love mine and would do it again in a minute.
  5. #4
    Join Date
    May 2008
    Location
    Detroit, Michigan & Lubbock, Texas
    Posts
    2,876
    Post Thanks / Like
    Default
    Quote Originally Posted by W7AX View Post
    Does it look anything like this?
ID:	21495   Click image for larger version.
  6. #5
    Join Date
    Dec 2005
    Location
    no need to know
    Posts
    1,052
    Post Thanks / Like
    Default
    Sure looks like a match to me
  7. #6
    Seasoned Member awingnut105's Avatar
    Join Date
    May 2005
    Location
    Seneca, SC
    Posts
    462
    Post Thanks / Like
    Default
    Quote Originally Posted by wobray View Post
    TIG
    I, too, have owned both units. Both are good, bit I prefer the IRS.
    '08 with '12 MT Adventure kit and '10 with '12 MT Adventure kit
    DISCLAIMER: All post are my personal opinion and are in no way intended to reflect on or change the opinions of others.
  8. #7
    Seasoned Member KJ5IX's Avatar
    Join Date
    Dec 2005
    Location
    Graham, TX
    Posts
    8,050
    Post Thanks / Like
    Default
    Quote Originally Posted by trike lady 1500 View Post
    That is a BAD comparison,,,,, to compare a no flex system to an IRS,,, The question as I understood it was between the Motor Trike Solid axle, and their IRS. As for the solid axle system that they use here is how it works. The IRS system is similar but with a straight mount to the frame.
    Ladder Bar General Description:
    The Motor TrikeŽ Patented Ladder Bar suspension allows the rear end to move on both sides independently to move up and down without the other side being affected. Ladder Bars are made of Chrome Molly tubes with race car type Hiem adjustments for a perfect alignment. The air ride allows you to set your own pressure for a custom ride, soft to hard, for one or two riders, or with a trailer. The shocks are gas coil-over from Progressive Suspension Products.
    All Motor TrikeŽ kits are manufactured using Air Ride Suspension as standard equipment. Which offers a true suspension, letting the shock absorbers do what they were designed for...to dampen sudden and rapid motion. The comfort and stability of the Air Ride Suspension will give a ride that is considered "unsurpassed in the industry"
    . When you combine the Air Ride Suspension with the Ladder Bar suspension, the result is unique in that the ride quality and handling characteristics split the difference between the traditional solid axle design, and the independent rear suspensions.
    The Ladder Bars attach to the inside of the motorcycle frame at the Swing Arm Pivot Point, and rear axle housing via beefy Hiem Joints, the upper Hiems are canted forward to reduce drive shaft velocity, and level the forward end of the drive line, and provide a slightly progressive lever ratio of the drive shaft. Chrome Molly Tubular steel adjustment arms fitted with aircraft type Hiem joints that provide total freedom of movement (adjustment) along with a huge increase in strength over bushings. There is a Ladder Bar on each side of the frame.
    George Patrick Th.D.
    2012-GL1800,Hannigan Gen2
    2009 Roll-A-Home
    CMA Chapter #854
    USMC 66-74
    Heb 13:2
  9. #8
    Join Date
    May 2008
    Location
    Posts
    2,876
    Post Thanks / Like
    Default
    Ok, I understand your concise, precise and well written explanation of the differences. But isn't this a quote from Motor Trike?
    "When you combine the Air Ride Suspension with the Ladder Bar suspension, the result is unique in that the ride quality and handling characteristics split the difference between the traditional solid axle design, and the independent rear suspensions."
    Now on paper it sounds real good and to a non-Triker it may fool them into thinking it rides nice, but having real life expereince with lots of Motor Trikes (Harleys, Hondas, 1800's 1500's etc.) having built them for 7 years and ridden three of my own nearly 200,000+ miles I can put t in my own words...........
    The Motor Trike IRS Adventure is a nice unit. Much nicer than the old style. I was glad to see they finally caught up with the real world and changed their design. They spent way too much time on that Stallion and ignored their bread and butter for years. Which is what lead me and others to take on the other brands we now offer. Then they got mad at the dealers that needed to stay in business which is one of the reasons I'm no longer a Motor Trike dealer. The other is a long story of how their word means nothng.
    The Ladder Bar design works fine and doesn't fall apart. It does have inherent flaws though. Most noticably the Heim Joints squeak and need WD-40 all the time. The first disc brake system was junk and had to be replaced which MT did with no hesitation. The heim joints wear after a while causing clunks. The air bags are ok but why does the Hannigan suspension ride so smoothly with just the Progessivess? Those air bags leak air all the time and I can't tell you how many hours we've spent re-doing lines and connections to get them not too.
    The new Adventure is pretty good ride wise but the Ladder Bar is harsh, hard and will jolt your teeth loose. It does not split no difference between nothin' .......... yes I own one now and I'll tell ya' why, because I got it dirt cheap from another dealer who had three and couldn't sell them. I think with paint and my labor cost it was about $4,500.00 complete. I would prefer a Cobra, Hannigan or Roadsmith but I didn't have the money last April to afford one.
    And the line about "Unsurpassed in the industry" must have been written in the 1990's 'cause they got passed by quality IRS units along time ago.
  10. #9
    Join Date
    Dec 2005
    Location
    Graham, TX
    Posts
    8,050
    Post Thanks / Like
    Default
    You caught that right off the bat,, Yes it is a direct quote from MT.
    I like the ladder bar my self it doesn't beat me to pieces like you say, but I am tougher than you are too...... and not overly sensitive. I will give you 3/4 of your money back for the Trike just to get it out of your sight, and misery. Then you can move on to something that you would be pleased with,,,,
    Oh wait your getting married this spring, maybe I should consult wit the Bride to be first,,,, I may get a better deal,,,,,,,,,,
    2009 Roll-A-Home
    CMA Chapter #854
    USMC 66-74
    Heb 13:2
  11. #10
    Join Date
    Dec 2005
    Location
    no need to know
    Posts
    1,052
    Post Thanks / Like
    Default
    I guess different people have had different experiences with their older MT's. My old one was a 2003. After 60,000 miles of riding, I never had a problem with any of the Heim joints. I never had a brake problem and in fact I still had the original drum brakes which after 60K miles still were only slightly worn.Incidently, MT offered at one point to upgrade the brakes to a disc system and because my brakes worked so well I declined it. My brakes were much better than the later Champion for instance. I have a buddy I ride with who has a Champion solid axle. It's been a great trike for him but it certainly rides much worse than the MT with their solid axle trike. I have never ,ever had an air problem with the suspension system either. No leaks ever and totally reliable. As a matter of interest, Hannigan and others use the same basic components on the air system as does MT. I also like the Hannigan but what I don't like about them is simply the aesthetics. Too wide and that so called whale tail is plain ugly...at least to me. That said, the IRS MT is a very well made and thought out machine. If I was to buy a trike tomorrow, that's what I would demand. I realize that some folks may have had issues with the older MT but I never did.
  12. #11
    Join Date
    May 2010
    Location
    Posts
    2,005
    Post Thanks / Like
    Default
    Quote Originally Posted by KJ5IX View Post
    The pictures were used as a visual aid to show the two types available.
    A solid axle and an independent unit. If a person hasn't looked under each trike or seen the kits on display they may not know what they look like. Each company has their own version of solid axle and an independent suspension. I used these two as an example.
  13. #12
    Seasoned Member George Lewis's Avatar
    Join Date
    Jan 2004
    Location
    In the woods, southeast of Boerne, TX
    Posts
    2,550
    Post Thanks / Like
    Default
    I don't have the mileage that George and Lee do, but at 40,000, I have not had any problems with my MT! A friend has (had, he dumped it) a Champion and I could not list the problems he had before trading it in on a 2010 CSC. On this site, it seems other Champion owners have had various problems.
    I plan on adjusting my shocks like George P. recommended....just have not got to it.
    Gary, I am disappointed you are not happy with MT. I have not had any dealing with them as all is well with my installation, heim joints, air bags, etc (I use the lub GP recommended and no squeaks, etc. in the heim joints)
    Gary, when you come to Boerne to do my trike, please bring another one of those $4,500 kits (installed) and we will really be good friends....I will let you drive my tractor around too.
    Call ahead and I will have a 2010 waiting for your installation ....do you finance?
    Riding a red '11 Can-Am RT-S Spyder, and a '02 Orange GW/'05 Motor Trike kit.
    SAVE THE CHUPACABRA
    If you have not been to Luckenbach, you have not completed your journey.
    MY NAME IS GEORGE LEWIS. Retird USAF and Sony Corp. MY EMAIL IS: scoot62@aol.com
  14. #13
    Join Date
    Apr 2007
    Location
    Indianapolis, IN
    Posts
    572
    Post Thanks / Like
    Default
    My area is devoid of a full-time MT dealer, so it wasn't on my radar screen when it came time for us to trike. Based on our first trike experience with a solid axle trike for 3 years, and now an IRS trike for 1 year, I would go with the IRS design. I've not seen one bad post about the MT IRS.
    Mike
  15. #14
    Seasoned Member wb9uze's Avatar
    Join Date
    Jun 2009
    Location
    Noblesville, IN
    Posts
    1,035
    Post Thanks / Like
    Default
    Quote Originally Posted by George Lewis View Post
    George, I adjust my shocks to one notch higher on the right side than the left side. Is that what you refer to?
    I've been using silicone spray on my heim's so what does GP recommend?
    '09 GL1800 Pewter Silver Metallic(Bought 11/27/12)
    BT-45 Battlax front/Kuhmo rear
    Roadsmith (Loaded w/ Goodies)
    '08 GL1800 Black (Bought 11/18/09)
    Hannigan..Done 1/16/2012
    The "Blackbird"
    USAF 1955-59
  16. #15
    Join Date
    Dec 2005
    Location
    Graham, TX
    Posts
    8,050
    Post Thanks / Like
    Default
    Rex
    I set the shocks up to the next to the top notch, and adjust the ride with the air, and use ( when I can get it ) PDRP. It is used widely in aircraft and some times a little hard to find off an air port.
    2009 Roll-A-Home
    CMA Chapter #854
    USMC 66-74
    Heb 13:2
  17. #16
    Join Date
    Oct 2007
    Location
    Central Texas
    Posts
    9,236
    Post Thanks / Like
    Default
    I see no justification for airing differences with a trike kit manufacturer on the trike sub-forum. Most such stories have two sides but neither of them has anything to do with technical differences between between types of suspensions which is/was the focus of this thread.
    ______________________________________________
    Ben
    Austin, TX area
    Many bikes and trikes since 1955, mostly BMWs. Currently looking for a motivated seller with the right Airhead.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
