Oil Change for 2010 Goldwing
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 30 of 38
Thread: Oil Change for 2010 Goldwing
  1. #1
    Member
    Join Date
    Jan 2011
    Location
    Katy Texas
    Posts
    7
    Post Thanks / Like
    Default Oil Change for 2010 Goldwing
    I have a 2010 Goldwing and am wondering what the best oil and filter to use. Any suggestions
  2. Remove Advertisements
    GL1800Riders.com
    Advertisements
  3. #2
    Member
    Join Date
    May 2011
    Location
    ross ohio just north of Cincinnati
    Posts
    4
    Post Thanks / Like
    Default butch
    use the honda oil & filter. I've gotten over 400,000 miles on two wings with no problems whatsover on either bike. I also never used the synthic oil. I changed the oil & filter every 4,000 miles. It's not worth trying to save a buck.
  4. #3
    Seasoned Member Two Wheel Wing's Avatar
    Join Date
    May 2009
    Location
    Northeastern Pennsylvania
    Posts
    581
    Post Thanks / Like
    Default
    Oh boy, here we go... The can of worms has been opened...
    I'll start.. I use Honda synthetic blend 10w40 and Honda filters. Change oil every 5k miles, which is sooner than recommended interval from Mother Honda...
    Two Wheel Wing
    2009 GL1800 Metalic Silver Audio/Comfort
    Faith is more than believing that God can, it's knowing that God will.
    You can not help people permanently by doing for them what
    they could and should do for themselves..(Abraham Lincoln)
  5. #4
    Seasoned Member Bartman's Avatar
    Join Date
    Mar 2006
    Location
    Jacksonville, FL
    Posts
    8,888
    Post Thanks / Like
    Default
    Follow whats recommended in your owners manual. The engineers at Honda are pretty smart. I bet you've never had a problem with the oil you use in your car and you didn't have to ask strangers on the internet for advice.
    There is one rule which is stated in your owners manual. Don't use Energy Conserving Oil.
    Personally, I use Mobile 1 and a Wal-Mart filter. Change my oil every 10,000 miles and have never had an issue.
    Opinions are will vary wildly. Pick a brand, change it regularly and you'll have years of good service.
    So long and good bye
  6. #5
    Join Date
    Jan 2005
    Location
    Indiana
    Posts
    7,631
    Post Thanks / Like
    Default
    Follow the owners manual. At least until the warranty runs out. Then you can run at least twice the recommended mileage using synthetic!
    WalMart filters for me also
  7. #6
    Seasoned Member Wingleader09's Avatar
    Join Date
    Jul 2009
    Location
    Hunterdon County, NJ
    Posts
    7,737
    Post Thanks / Like
    Default
    Shell Rotella 15W-40 and Wal-Mart ST6607 filter!
  8. #7
    Join Date
    Mar 2009
    Posts
    247
    Post Thanks / Like
    Default
    im sure the next question will be how much. as i have said before gl1000 4 qts gl1100 4 qts gl1200 4 qts gl1500 4 qts gl1800 4 qts. im sensing a pattern. and i bet you could count on one hand the number of oil related failures, other than lack of on all wings. dont sweat it the big girls are fairly easy going on flavors of oil. just keep some in them and they will remain happy for many miles
  9. #8
    lightley seasoned member jburd's Avatar
    Join Date
    Mar 2004
    Location
    Niles, Mi.
    Posts
    3,120
    Post Thanks / Like
    Default
    Wheres Tim the Amsoil guru when you need him
    John
    2001 GL1800 base
    IBA # 25535
    "Could you explain that to me as if I we're a particulary gifted child or a golden retriever?"
  10. #9
    Seasoned Member batess6's Avatar
    Join Date
    Apr 2008
    Location
    Bullhead City, AZ
    Posts
    530
    Post Thanks / Like
    Default
    Quote Originally Posted by garcoal View Post
    4 quarts is what I put in.
    it gets it to the full mark everytime. Only Honda.
  11. #10
    Seasoned Member Biker John's Avatar
    Join Date
    Apr 2006
    Location
    Michigan...................................... In The Thumb
    Posts
    7,794
    Post Thanks / Like
    Default
    Quote Originally Posted by batess6 View Post
    Can you run it twice as far between changes?
    John
    If Riding A Wing Is A Mid life Crisis....Bring It On!
    2006 Dark Red GL 1800
    Gold Wing, Adopted 4-21-06 Premium Audio/Comfort
    R.I.P. Beverly, You'll be Missed!
    R.I.P. Harry
    R.I.P. Chuck
    The "Black Pirate" has left us a message.
    Did you get it?
    DS 1020
    Michelin Primacy Alpin PA3 195/55/16 ZP
  12. #11
    Contributing Member Speed Bump's Avatar
    Join Date
    Aug 2008
    Location
    Bethalto, IL
    Posts
    48
    Post Thanks / Like
    Default
    Bartman,
    The mobile one you use is it regular mobile one or something for motorcycles specifically? Thanks for your help.
    Jeff Smith
    '03 GL 1800 Silver
  13. #12
    Seasoned Member wing-renter's Avatar
    Join Date
    Sep 2004
    Location
    Tucson AZ
    Posts
    1,815
    Post Thanks / Like
    Default
    Any oil, any filter - they're all good.
    PS Do you own a car? What determines what oil and filter you use in it?
    2008 Goldwing
  14. #13
    Seasoned Member Peteswing's Avatar
    Join Date
    Nov 2010
    Location
    Wellington, FL
    Posts
    511
    Post Thanks / Like
    Default
    Honda filter any brand of oil will do.
    2010 Pearl Yellow Comfort,Audio,Navi,XM
    Ultimate Midrider two tone Yellow/Black
    F4 +4 Tinted
    ShowChrome Trunk + Saddlebag Lights
    Kuryakyn ArmRest
    Kuryakyn Leg Rest Pegs
    Baker Air Wings
    Double Darksider #856
    Bridgestone Turanza Run Flat 195/55/R16
    Bridgestone BT 45 Battlax 130/70/18 front
    Dyna Beads 2oz front 3oz rear
  15. #14
    Chromeaphobe laen's Avatar
    Join Date
    Nov 2005
    Location
    Houston, TX
    Posts
    16,880
    Post Thanks / Like
    Default
    OEM Filter
    Motorcycle Specific Oil
    See manual for velocity
    3.9 Qts
    2010 Red GL1800 Traxxion/Centramatic
    2005 Silver GL1800-TE(sold)
    LIMNCS#1, GWRRA
    Iron Butt-B2B,BB1500,SS1000
    Michelin Alpin PA3-R, B'Stone 709-F
  16. #15
    Join Date
    Mar 2006
    Location
    Jacksonville, FL
    Posts
    8,888
    Post Thanks / Like
    Default
    Quote Originally Posted by Speed Bump View Post
    Bartman,
    Regular Mobil 1 from Wal Mart.
  17. #16
    Seasoned Member rickathome's Avatar
    Join Date
    Nov 2005
    Location
    columbus ms
    Posts
    2,828
    Post Thanks / Like
    Default
    Some folks highly recommend Amsoil (made by Amway ??) and only the most expensive filters available.
    Is it really true that the yellow ones are faster, get better mileage, etc, etc, etc?
    email: rickavethlove@cableone.net
  18. #17
    Join Date
    Sep 2004
    Location
    ZEPHYRHILLS, FL
    Posts
    9,927
    Post Thanks / Like
    Default
    Quote Originally Posted by butch royse View Post
    ... if it helps, look at post #29 on the link below.
    http://gl1800riders.com/forums/showthread.php?t=284770
  19. #18
    Seasoned Member kwthom's Avatar
    Join Date
    Sep 2006
    Location
    Jaynes Station (where?), AZ
    Posts
    5,963
    Post Thanks / Like
    Default
    Quote Originally Posted by Wingleader09 View Post
    Did a couple of changes so far with this, after being on sythetic Mobil 1 for 40k...so far, no issues. Agree on the on this combination, simple, cheap and readily available.
    Chage at about the 6k to 8k range (so not into being anal retentive on this...) and life is good.
    This means, I change oil about 2x year, riding ~12k annually.
    ● DS #512 ● "Get busy living, or get busy dying." -Andy Dufresne, The Shawshank Redemption 1994ΜΟΛΩΝ ΛΑΒΕ
    Search Problems? Try this with Google: <search term> site:gl1800riders.com
  20. #19
    Seasoned Member TXREALTOR's Avatar
    Join Date
    Jan 2009
    Location
    Trinidad, Tx
    Posts
    3,222
    Post Thanks / Like
    Default
    Quote Originally Posted by laen View Post
    OEM Filter
    3.9 Qts
    I like my oil about 3000 ft/sec. LMAO, sorry just couldn't resist.
    My personal is Rotella. 15W-40 or 5W-40 Synthetic and the Supertech 7317.
    Any non energy conserving oil in a 10W-30 or 10W-40 ish weight and a good filter will do. If OEM floats your boat, go for it.
    Now, to make it a proper rant, the crush washer must be reused if you don't have a new old one. Oh and don't even think of putting it in up side down. LMAO
    Cheers and Good Riding, Keith
    DROP, FALL, AND DOWN ARE 4 LETTER WORDS
    I, my typing, and spelling are far from perfect. Get over it.
  21. #20
    Contributing Member
    Join Date
    Jan 2011
    Location
    Katy, Texas
    Posts
    39
    Post Thanks / Like
    Default Oil is Oil
    I don't profess to be a petroleum engineer, but I asked one a number of years ago as to what was the "best" oil. He said, "Oil is oil as long as it's new, it's the additives that make a difference. The better oil has additives to clean and keep the particles in suspension so the filter can take them out." I was also told about a project where they ran an engine at the RPM equivalent of 70MPH for 200K miles, only stopping to change the synthetic oil. After tearing the engine down he said the wear was virtually unmeasurable.
  22. #21
    Join Date
    Apr 2011
    Location
    Emmett, Id
    Posts
    1,766
    Post Thanks / Like
    Default
    Quote Originally Posted by #1Dragonheart View Post
    I am curious as to just how often that they changed the oil. If the oil was changed the equivalent of every 5,000 miles then that would not be near as impressive as if they changed it every 50,000 miles.
  23. #22
    Join Date
    Sep 2010
    Location
    King Geroge VA
    Posts
    676
    Post Thanks / Like
    Default
    you will get a diffrent opinion from everone that posts to this thread...
    That said, read the owners manual for Honda's recomedations.
    I put Shell Rotela T-6 in my bike. four quarts, I just empty the entire jug....
    I use a Purolater PureOne filter.
    Keep it breezy...
    P.S. The wind is like air, only pushier.
    Current rides:
    MMX Honda Gold Wing VIIA, Titanium & '50 Harley-Davidson FL, Light Blue (For Sale but NOT cheep)
    Darksider #1443, as Joun Cafferty wrote "The dark side's callin' now Nothin' is real"
  24. #23
    Seasoned Member The Bear's Avatar
    Join Date
    Mar 2004
    Location
    Norcross, GA
    Posts
    548
    Post Thanks / Like
    Default
    It has been a while since we have had one of these threads...I kinda miss them. For the entertainment value, if nothing else.
    Rob
    "The Bear"
    2010 GL-1800 Level 4
    2007 V-Star 1300T
  25. #24
    Join Date
    Jan 2011
    Location
    Pleasant Grove, Utah
    Posts
    304
    Post Thanks / Like
    Default
    For a motorcycle with a wet clutch USE A MOTORCYCLE SPECIFIC OIL.
    Personally, I am using AMZOIL Motorcycle FULL SYNTHETIC and changing once a year or every 15000 miles.
    Amzoil is NOT MADE/MARKETED BY Amway! to answer the query sort of asked in a previous post!
    States visited since taking delivery of 2010 GL1800 Champion Trike Conversion Jan 27, 2011
  26. #25
    Seasoned Member montero1's Avatar
    Join Date
    Oct 2006
    Location
    Northern MD
    Posts
    963
    Post Thanks / Like
    Default Amsoil
    Quote Originally Posted by PilotJO View Post
    Is not spelled with a "Z". You could go 15k on an OCI on this bike with several other quality synthetics as well.
    Double Darksider # 417
    Rear Michelin Pilot Sport... 130/70/18 Front
    Michelin Pilot Sport A/S3 ....195/55/R16 87V Rear
  27. #26
    Seasoned Member WestWing03's Avatar
    Join Date
    Aug 2009
    Location
    Way out West
    Posts
    343
    Post Thanks / Like
    Default
    What would the Engineers that created the 1800 know about what oil and filter that it requires?
  28. #27
    Join Date
    Jan 2011
    Location
    Posts
    304
    Post Thanks / Like
    Default
    Quote Originally Posted by montero1 View Post
    yep, I know the spelling... I am a dealer, but I wasn't pushing that part!
  29. #28
    Join Date
    Mar 2009
    Location
    Hagerstown, Maryland
    Posts
    3,827
    Post Thanks / Like
    Default
    Suggestion (JMO):
    - Honda OEM oil filter
    - 4 qts. Honda (Idemitsu) 10W-30 full-synthetic every 8k, as manual
    recommends
    Quote Originally Posted by gwj25 View Post
  30. #29
    Guest
    Join Date
    Jan 2008
    Location
    As the new way, somewhere
    Posts
    13,239
    Post Thanks / Like
    Default
    I kinda like the slick kind of oil. I have found that works the best.
    Round filters seem to work best also.
  31. #30
    Seasoned Member Destindoc's Avatar
    Join Date
    Oct 2007
    Location
    Western Montana
    Posts
    1,905
    Post Thanks / Like
    Default
    Once again... Kit is on the mark! Can't go wrong with that advice...
    I don't profess to be a petroleum engineer, but I asked one a number of years ago.....
    Hey, I'm not a petroleum engineer either, but I slept at a Holiday Inn Express last night and:
    I use OEM Honda filter.... I buy them from HAL and it's what my wrench fits... I use Honda 10-30 dino oil... but, have used Pennzoil 10-40 dino oil, just because I like the yellow bottle... it matters not... no one can point to an engine failure or damage due to filter or oil, no matter what was used as long as it was within recommended specs.
    Quote Originally Posted by Gary Klavans View Post
    Suggestion (JMO):
    recommends
    FULL synthetic is RECOMMENDED in the manual? I don't recall that...
    ...forget to replace the crush washer and, holy cow, don't EVEN show your face on this board again.........................
    2008 Goldwing ABS
    2004 CBR 1000 RR
    2009 KLR 650
    ...wife has her own 2006 Goldwing...
    A stop at the top of Beartooth Pass.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
