Tire Bead Won't Seal... Non-Wing
+ Reply to Thread
Results 1 to 23 of 23
Thread: Tire Bead Won't Seal... Non-Wing
  1. #1
    Seasoned Member ATCguy's Avatar
    Join Date
    Mar 2005
    Location
    southeastern NC, but currently in Casa Grande, AZ for the winter
    Posts
    4,032
    Post Thanks / Like
    Default Tire Bead Won't Seal... Non-Wing
    For you guys that mount your own tires on other bikes besides Wings... have you ever run across a set of tires that you couldn't get the bead to set?
    If so...
    * What did you discover the problem was, and...
    * How did you solve the problem?
    Here's what I've got:
    I'm trying to mount a pair of off-road Continental TKC 80 tubeless tires on a brand new set of BMW spoke-wheels for an R1200GS. And yes, I said SPOKE wheels. The BMW spoke wheels are made for tubeless tires by lacing the wheel to the outside edge of the rim. You can see the tire & type wheel in the picture below:
    Mounting the tires was simple enough, and I'm using a Craftsman 30 gal compressor set at 90psi to inflate them... as I've used successfully on at least 20 other sets of tires.
    But for some reason, I just can't get these babies to seal. I can't even get the bead to set good enough to get 15 lbs of pressure in them. I've run my hand all over & under the tire while trying to inflate it, and can't feel any significant air leaks. I've tried using 2 ratchet straps across the tires at the 12 & 9 o'clock and 3 & 9 o'clock positions. I've tried different valve cores. All to no avail.
    As of now, I'm out of ideas... except to break down and take them to a garage with a higher, commercial grade compressor.
    Any other ideas?
    __________________
    USMC: '81 - '89
    FAA: '92 - '13
    AMA - BMW MOA
    '07 Honda GL1800A Goldwing
    '14 Ford F-450 PLATINUM
    '14 Dutchmen VOLTAGE 3200 5th Wheel Toy Hauler
  2. Advertisements
  3. #2
    Guest
    Join Date
    Jan 2008
    Location
    As the new way, somewhere
    Posts
    13,239
    Post Thanks / Like
    Default
    Take those straps and run them around the outside diameter of the tire. Pull the tire down into the wheel, pretty sure it will seat that way .
  4. #3
    Veteran Member wingwing's Avatar
    Join Date
    Nov 2006
    Location
    Agrestic, Florida WW/MM
    Posts
    10,937
    Post Thanks / Like
    Default
    squirt some "ether" or starting fluid inside the tire..
    (anything highly volatile)
    .. just a bit, you don't want to attract homeland security...
    .. light it and IT WILL seat.
    no joke, it works.
    Dennis
    Life..DS#99/Prowler#0
    ​.. it's the right thing to do
    ..wake up on the right side of history or remain forever more in the dark ages..
    REMINDER:
    All truth is at first ridiculed, then opposed, and finally self-evident..
    ..two down and one to go!
    If YOU have to keep telling your smart phone what to do, it ain't so smart.
    ...Ride Safe, Avoid R.U.D.
  5. #4
    Seasoned Member illusionblue_wing's Avatar
    Join Date
    Mar 2007
    Location
    Show Me State
    Posts
    2,486
    Post Thanks / Like
    Default
    I would try a ratchet strap,if that dosen't work you could always go the wd40 route
    [ame]http://www.youtube.com/watch?v=DyuHco1Z12Y[/ame]
  6. #5
    Join Date
    Aug 2004
    Location
    Terre Haute IN.
    Posts
    2,254
    Post Thanks / Like
    Default
    take the valve core OUT until you have it seated!!! then deflate & install
    chuck
    2001 gl 1800 pearl blue
    LIMNCS 1047
  7. #6
    Seasoned Member MarkEkberg's Avatar
    Join Date
    Sep 2009
    Location
    Belmont NH Bought the house I grew up in 12/12
    Posts
    1,844
    Post Thanks / Like
    Default
    You might just need some more air?
    Larger hose, larger did air chuck, take stem out.
    If all else fails you can use the lighter fluid route. WD40 does not work anymore. It is not flammable enough.
    SHOW ME A GOVERNMENT THAT WILL GIVE YOU EVERYTHING YOU NEED AND I WILL SHOW YOU A GOVERNMENT THAT WILL TAKE EVERYTHING YOU HAVE.
  8. #7
    Seasoned Member SneakySnake's Avatar
    Join Date
    Jun 2006
    Location
    Western Kentucky
    Posts
    1,032
    Post Thanks / Like
    Default
    Quote Originally Posted by Kit Carson View Post
    That is the way I do it. If you still have problems try bouncing it on the floor while rotating it.
    2002 Orange Goldwing DFT Trike
  9. #8
    Join Date
    Apr 2006
    Location
    Center Line, MI (north of Detroit)
    Posts
    880
    Post Thanks / Like
    Default
    Here's a video of wingwing's method of seating a tire [ame="http://www.youtube.com/watch?v=7owrxqMFSy8"]http://www.youtube.com/watch?v=7owrxqMFSy8[/ame] .
    Ken
    I have reached the age where I know that I can not please everyone however pi$$ing everybody off is a piece of cake !
  10. #9
    Seasoned Member DBohrer's Avatar
    Join Date
    Mar 2006
    Location
    Silver Spring, MD
    Posts
    1,176
    Post Thanks / Like
    Default
    Quote Originally Posted by wingwing View Post
    no joke, it works.
    Dennis
    Dennis, You must have watched the IRT (Ice Road Truckers) show. They did that to get an 18-wheeler tire to seat. It worked well........!
  11. #10
    Join Date
    Nov 2006
    Location
    Posts
    10,937
    Post Thanks / Like
    Default
    Quote Originally Posted by DBohrer View Post
    actually, used to race stock cars as a kid... (back in the '60's)
    ... sometimes used the starting fluid "trick" to change tires in the pits
    .... didn't have no fancy tools.
    Dennis
    REMINDER:
  12. #11
    Join Date
    Aug 2008
    Location
    Chicago, Illinois
    Posts
    1,514
    Post Thanks / Like
    Default
    You are putting some kind of lube on the tire beads so they slide on the rim, right?
    2007 Comfort/Nav/ABS
    Prior:
    1993 ST1100
    1983 CX650
    I'll go totally green and give up my GoldWing when Al Gore gives up his charter jet.
  13. #12
    Contributing Member yzgrbr's Avatar
    Join Date
    Oct 2009
    Location
    Chetwynd BC
    Posts
    90
    Post Thanks / Like
    Default
    Agree with others, use a decent tire bead lube and remove the valve stem. the lube works as a sealant as well. if you can't find tire lube, i've used a bit of grease in a pinch.
    Brent in BC
    Titanium 08
    Leesure lite
    Kumho Ecsta SPT run flat 195/55R-16
    Darksider #478
  14. #13
    Join Date
    Mar 2005
    Location
    Posts
    4,032
    Post Thanks / Like
    Default
    Thanks guys... Got the rear wheel done, but still no joy on the front. And yes, I did use lube.
    Tried running the ratchet strap around the circumference of the tire... did nothing.
    Finally began spraying ether (starting fluid) into the rear. Almost singed my eyebrows off, but the bead set and I got it inflated.
    Began on the front. Sprayed the ether... lit it... and all it did was burn around the rim of the wheel. Thinking I must not have gotten the ether into the tire, I pressed down on the sidewall and made sure this time I sprayed inside the tire. Lit it again and got the same result. When I pressed down on the sidewall, the flame just got a little higher is all, until I eventually blew it out.
    Tried it again... same result.
    Disgusted & pissed... I just walked away.
    The funny part of this whole thing is that I mounted an identical set of these tires on wheels like these last year with no problems at all. But these are kicking my ass so far.
    Another question since I'm here:
    I got a box of tire valves awhile back that are also giving me problems occasionally. They are stainless, and I bought an assortment of straight, 45-degree, and 90-degree valves. The problem appears to be with the valve cores.
    When I put air to them... occasionally I hear a distinct "POP" a half-second later, and then no air goes in. Most times I can remove the air chuck, start again, and air flows normally. But other times, no matter what I do or how many times I repeat applying air... I keep hearing the POP, and air flow stops. It's almost like there's a secondary or 1-way flap that won't let any air in. In a couple of cases, I've had to completely remove the new core, and put in an old one to make the thing work.
    I can hold one of these valve stems in my hand (not installed on a wheel), and get the same results. When removed, the cores look exactly the same as any other core I've seen, except these have a red-colored o-ring to seal them.
    Am I missing something? Are there different types of valve stems and/or cores that need special air chucks or something... or did I just get a bad batch of stems?
    __________________
    USMC: '81 - '89
    FAA: '92 - '13
    AMA - BMW MOA
  15. #14
    Guest
    Join Date
    Jan 2008
    Location
    Posts
    13,239
    Post Thanks / Like
    Default
    Are you taking the valve core out to seat the bead?? Gotta have lots of air to pop some of then into place. Especially if the tires are a bit narrow for the rim.
  16. #15
    Join Date
    Mar 2005
    Location
    Posts
    4,032
    Post Thanks / Like
    Default
    I've tried both ways... valve core in & out. Just a stubborn tire, I guess. Think I'll probably end up taking it over to my friend at the airport, and let him use their commercial compressor. I think the output on their machine is in the 175-psi range for aircraft tires, and that should do it.
    __________________
    USMC: '81 - '89
    FAA: '92 - '13
    AMA - BMW MOA
  17. #16
    Join Date
    Jan 2005
    Location
    Fayetteville, NC
    Posts
    340
    Post Thanks / Like
    Default
    One other way I have had luck with an agravating tire is to unmount one side and place a few wide short boards on edge under the edge of the tire to make it stretch out and leave it that way for a while where it is cool. (will not work with the tire warm) Then after the tire is stretched and will retain that shape, remount it then try inflating it. It has worked for me several times.
    Give me a crooked road and a good handling bike.
  18. #17
    Join Date
    Dec 2008
    Location
    Gold Canyon, Arizona
    Posts
    583
    Post Thanks / Like
    Default
    I had that happen with a set of car tires. I got 3 of them mounted with no problem, but the 4th wouldn't go on for the life of me. Tried everything mentioned here. I finally figured out that the distance between the tire beads was about 3 inches narrower than on the other tires. When I mounted that tire both beads were sitting in the lower part of the wheel center and those beads were not going to set...period. I bought the tires from Tire Rack, gave them a call and they replaced it. Mounted the new one with no problem. The guy I spoke with said every now and then this happens, could be from improper storeage or maunfacturing problem. If the tire is too narrow at the beads you may never get it on and if you do it may not hold air like a "good" tire. If you could measure the beads and compare that tire with a good one, you would probably find a big difference in the width between the beads.
    Gary
    2002 GL1800
  19. #18
    Seasoned Member Rocketman911's Avatar
    Join Date
    May 2009
    Location
    Tennessee Valey area, Alabama
    Posts
    17,662
    Post Thanks / Like
    Default
    ATCfguy, what I have done in the past is valve my wife hold the leaf blower blowing air into the tire at the rim. Then I hit it with the air from the compressor at the valve stem.
    Nokian WR D3 R/F
    Vredestein Quatrac 3 REAR 195 55 16 R/F
    Bridgestone G 709 Front
    December 27, 2010 - 102 posts
    JPINPA my friend forever
  20. #19
    Contributing Member
    Join Date
    Mar 2009
    Location
    Clearlake Oaks, Ca
    Posts
    35
    Post Thanks / Like
    Default
    Bouncing it on the floor while pumping the air in has worked for me.
  21. #20
    Join Date
    Nov 2003
    Location
    Wi. Rib Lake
    Posts
    16,210
    Post Thanks / Like
    Default
    Quote Originally Posted by James I. Jones View Post
    had that problem with a front tire for a 1500 wing once, i think it was caused by shipping, they had 2 tires tied together so tight that it caused the beads to stay not in the normal position but way closer together, the rear tire gave me a little trouble but eventually i got it to seal, the front tire was way more trouble, i wound up taking it off the rim and using some wood blocks for spacers to hold the beads apart overnight, the next day i still had a little trouble getting it to seal but it worked
    ehcycledude@yahoo.com
    02 GL1800 yellow 457,000 smiles
    Rode my bike to Trailer Week
  22. #21
    Join Date
    Mar 2006
    Location
    Michigan
    Posts
    1,228
    Post Thanks / Like
    Default
    Have you tried leaving the tire in a closed vehicle in the sun to warm it up first then use the strap to draw it down?
    Darkside #750
    Michelin Primacy Alpin PA3 195-55-16 ROF @28 PSI
    Bridgestone 709 Front @ 36 psi
    Centramatics
    F4+4 with vent
    Baker Wings full monte
  23. #22
    Join Date
    Mar 2005
    Location
    Posts
    4,032
    Post Thanks / Like
    Default
    Ok... took it to the aircraft hanger, and using their machine (at 120psi) and an extra set of hands to hold the tire tight against the rim... it finally began to hold air and sealed.
    What a PITA that was...
    __________________
    USMC: '81 - '89
    FAA: '92 - '13
    AMA - BMW MOA
  24. #23
    Seasoned Member ChrisE's Avatar
    Join Date
    Aug 2010
    Location
    Lewisville,TX
    Posts
    3,019
    Post Thanks / Like
    Default
    Sometimes, when I get tires delivered, they are often squashed a little flat by the zip ties on the packing. So the crown of the tires are a little pointy.
    I put an old inner tube inside the tires, inflate it a little bit wider than the beads would be on the rim and then sit it in the sun for a few hours. This is while the new tires are still off the bike. I'll leave it like this until minutes before I do the actual install.
    I also replaced all my 1/4" npt fittings with 3/8" fitting on my air hoses. You get more volume of air through quickly.
    My Toys (Current Stable)
    '15 Ducati Multistrada (on order)
    '12 Aprilia Tuono V4 APRC
    '08 GL1800 (Level 3) Traxxion Full Monty, '04 Uni-Go Trailer (Sold)
    '07 Suzuki GSXR1000
    '08 KTM 300XCW
    '07 Ducati 1098S
    '98 Yamaha R1
    '93 Bimota DB2
    '75 Honda CB400F
    DS #1166 (Once)
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
