GL Engine 1800cc eqals what horsepower?
+ Reply to Thread
Results 1 to 19 of 19
Thread: GL Engine 1800cc eqals what horsepower?
  1. #1
    Join Date
    Feb 2005
    Posts
    367
    Post Thanks / Like
    Default GL Engine 1800cc eqals what horsepower?
    What formula works to figure out what a 1800cc engine is how many horse power?
    thanks
  2. Advertisements
  3. #2
    Seasoned Member FUSE's Avatar
    Join Date
    Nov 2004
    Location
    Germantown, MD
    Posts
    3,812
    Post Thanks / Like
    Default
    Don't know about a formula. I did put mine on a dyno earlier this year. It was 75 degrees, pressure at pretty much sea level - 0% correction all around. Final numbers is 103hp at 5400 RPMs and 118 lbs torque at 3400 RPMs. The power curve is fantastic. Very smooth. I'm happy.
    Ray aka "FUSE"
    A lil ol' video I made in 05'.
    http://www.youtube.com/watch?v=0nrMQ3QwyPo
  4. #3
    Contributing Member SteveGW1800's Avatar
    Join Date
    Jul 2011
    Location
    Freeport, ILL
    Posts
    51
    Post Thanks / Like
    2002 Goldwing
    2006 Shadow Aero
  5. #4
    Join Date
    Nov 2004
    Location
    Germantown, MD
    Posts
    3,812
    Post Thanks / Like
    Default
    To clarify my numbers are at the rear wheel. I understand the 118hp number is at the crank.
    Don't matter which number you really use, they both are from the same machine and give you the same huge grin when twisting that right wrist...
    Ray aka "FUSE"
  6. #5
    Join Date
    Jul 2011
    Location
    Freeport, ILL
    Posts
    51
    Post Thanks / Like
    Default
    Engine Displacement
    • Engine displacement refers to the total volume that the pistons of an engine occupy after firing. Typically, the higher an engine's displacement, the more power it is able to generate. The Gold Wing 1800's engine has a displacement of 1,832 cc, which is equivalent to approximately 112 cubic inches.
    Horsepower
    • The Gold Wing 1800 is able to obtain an optimal power output of 118 horsepower when its engine is running at 5,500 rotations per minute (RPMs).
    Torque
    • Torque is the amount of twisting force -- or rotational effort -- that the firing pistons of the engine are able to exert on the crankshaft. The Gold Wing 1800 is able to generate an optimal amount of torque -- of 123 foot-pounds -- at 4,500 RPM.
    Read more: Specifications for a Gold Wing 1800 | eHow.com http://www.ehow.com/list_7490383_spe...#ixzz1cD2yRFT6
    2002 Goldwing
    2006 Shadow Aero
  7. #6
    Seasoned Member 05nwl's Avatar
    Join Date
    Aug 2007
    Location
    Huntington Beach
    Posts
    3,703
    Post Thanks / Like
    Default
    Most get about 95-105 hp at 5500 rpm and 105-110 ft lbs at 4250 rpm at the rear wheels. Depends on the dyno and conditions at time of dyno run. Torque is over 90 ft lbs from 1500-5500 rpms. That's why its such a great touring motor.
  8. #7
    Seasoned Member 2Wheeler's Avatar
    Join Date
    Oct 2006
    Location
    Marshall County, AL, Home of Frogg Toggs
    Posts
    1,021
    Post Thanks / Like
    Default
    Cubic displacement is not really an accurate indicator of how much power an engine is capable of delivering. A perfect example of this is the 750cc Magna that was discontinued after 2003. The bike is light, which is a factor; however, the Magna 750 has the most powerful 750cc engine I have ever seen in a cruiser. The bike itself is somewhere in the size and weight range close to a Shadow 750, etc., but the V-twin Shadow cannot compete with a 750 Magna with 4 cylinders and 4 carburetors. In terms of power and speed, there is no comparison. As a matter of fact, the VTX 1300 I had was not even in competition with the 750 Magna one of my son's buddies rides. It is one little hoss of a bike with close to sport bike performance.
    2W
  9. #8
    Join Date
    Mar 2009
    Location
    Hagerstown, Maryland
    Posts
    3,830
    Post Thanks / Like
    Default
    The HP and Torque figures stated below (at the rear wheel) are correct, and the combination of big torque just off idle and down low in the rev range, combined with the cremey smoothness of the flat-6 configuration make the GL1800 the greatest touring motor!
    Quote Originally Posted by 05nwl View Post
  10. #9
    Contributing Member roundgunner's Avatar
    Join Date
    Mar 2008
    Location
    Rural, CT
    Posts
    55
    Post Thanks / Like
    Default
    From the Dyno Drags at Honda Homecoming 2006. This puppy will run if ya want it to!
    Warren
    We could certainly slow the aging process down if it had to work its way through Congress.
    - Will Rogers
  11. #10
    Join Date
    Aug 2007
    Location
    Huntington Beach
    Posts
    3,703
    Post Thanks / Like
    Default
    Quote Originally Posted by roundgunner View Post
    Wow. 12 "flat" is the quickest time I've seen for a GL1800. Is a "dyno drag a simulated run? What year is the bike?
  12. #11
    Crazy Northerner vettesherps's Avatar
    Join Date
    Aug 2006
    Location
    Oshkosh, Wi
    Posts
    6,804
    Post Thanks / Like
    Default
    The GL1800 HP = fastest enough to get a ticket. (ouch)
    GL1800riders.com WI Board's Toughest Riders (Charter Member).
    Real Riders Ride Year Round. Cold is only a state of mind, but snow
    sucks. Charter member of the "I Hate Snow" club.
    Darksider #1025
    Wisconsin Patriot Guard #188329
  13. #12
    Join Date
    Mar 2008
    Location
    Rural, CT
    Posts
    55
    Post Thanks / Like
    Default
    it gets strapped down then you run with a light tree. I used to drag this 76 750k built up to a 836 with lots of extras at Milan, Mich. I don't think it ever got 12 flat.
    Warren
    - Will Rogers
  14. #13
    Join Date
    Aug 2007
    Location
    Huntington Beach
    Posts
    3,703
    Post Thanks / Like
    Default
    I've seen 12.70's, which is plenty quick for a fat lady. So, the fat lady sings! Sorta.
  15. #14
    Seasoned Member bluestreek-02's Avatar
    Join Date
    Feb 2004
    Location
    Grabill, Indiana / Sarasota, Florida
    Posts
    5,610
    Post Thanks / Like
    Default
    Quote Originally Posted by FUSE View Post
  16. #15
    Seasoned Member Hornkhonker's Avatar
    Join Date
    Aug 2005
    Location
    Victoria BC Canada
    Posts
    132
    Post Thanks / Like
    Default
    Didn't the early 1800s make more power before the ECU swap out ?
    2012 BMW K1600GT
    2000 BMW R1100R
    2010 Wing Airbagger Sold
    2008 Burgman 650 Exec
    Past Bikes of note: Suz RG500, 250RGV, 500 Titan, 250 Hustler, Hon CBX, CB305 Super Hawk, Kaw Z1, 500 triple, Yam 350LC, Twin Jet 100, RZ500.
  17. #16
    Join Date
    Aug 2005
    Location
    Victoria BC Canada
    Posts
    132
    Post Thanks / Like
    Default
    Did they get a reading of the AFR in the pipes ?
    2012 BMW K1600GT
    2000 BMW R1100R
  18. #17
    Join Date
    Nov 2004
    Location
    Germantown, MD
    Posts
    3,812
    Post Thanks / Like
    Default
    Quote Originally Posted by Hornkhonker View Post
    Nope. This was just a pure power baseline run. No AFR done since there was to be no tuning what so ever. Was just worried about pure numbers. Plus it was free so I wasn't going to ask for anything extra then what they were offering.
    Ray aka "FUSE"
  19. #18
    Seasoned Member cgent's Avatar
    Join Date
    Mar 2006
    Location
    Winchester, Indiana
    Posts
    1,766
    Post Thanks / Like
    Default
    My Honda has slightly less than 1800 c.c.'s ... but 140 horse power ... and only four cylinders ...
    ... oh ... you meant my motorcycle ... I was talking about my Honda CIVIC ...
    Tom Batt ... the "FROGG TOGGS GUY"
  20. #19
    Join Date
    Aug 2007
    Location
    Huntington Beach
    Posts
    3,703
    Post Thanks / Like
    Default
    Quote Originally Posted by 2wing View Post
    thanks
    BTW, there is no formula to go directly from displacement to horsepower. Too many variables. The GL1800, 111 cubic inches, makes about one horsepower per cubic inch, which is a really mild engine by today's standards. Some of the streetable liter-class bikes, 1,000 cc, 61 cubic inches, make almost three horsepower per cubic inch at the rear wheels! Of course, they are spinning a lot faster than the GL1800.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Where do you live?
Your rides, Bikes, Cars?
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
