08 GL1800 Reverse Problem
+ Reply to Thread
Results 1 to 11 of 11
Thread: 08 GL1800 Reverse Problem
  1. #1
    Member
    Join Date
    May 2011
    Location
    Whitesboro TX
    Posts
    4
    Post Thanks / Like
    Default 08 GL1800 Reverse Problem
    My GW had been "triked" when I purchased it and all worked well for about 6 months. After that, I began having problems when attempting to use the reverse function. At first it was intermitten and has now become an all the time problem.
    The malfunction is that when reverse function is activated and the starter button is depressed, the mc will only backup about 4 or 5 feet (3-4 sec) then stop with the reverse indicatior going off (neutral ind not on either). To continue in reverse, the reverse button must be released allowing the unit to switch back into neutral, then repeat the action all over. This can be done again and again. Unit was put into the dealers shop for 2 days, to no avail, with the reverse/cruise module having been changed. (No charge for that since the problem wasn;t fixed) I've since discovered that if I simply release the start button and after a count of 3, then depress it again, the dis-engage/engage action does not have to be done. I can simply dis-engage/engage the start button over and over. Kind of herky-jerky but eventually gets me where I need to go. Does anyone have any ideas?
    08TrikeRider
  2. Remove Advertisements
    GL1800Riders.com
    Advertisements
  3. #2
    Join Date
    Aug 2009
    Location
    Northwest Mississippi
    Posts
    1,941
    Post Thanks / Like
    Default
    Quote Originally Posted by 08TrikeRider View Post
    08TrikeRider
    My '08 isn't triked but I have had that problem. All I did was to lube the cam area where the cables hook up at the engine end. There is a spring that seems to bind sometimes. I use a gun oil spray with teflon evey time I change oil (4K) and haven't had the trouble since! Check and see if the installer adjusted the cables to where there is not enough free play, this can cause the problem too! Good luck
  4. #3
    Join Date
    Sep 2004
    Location
    Lexington, KY
    Posts
    13,434
    Post Thanks / Like
    Default
    If the cables are OK, then check fuse #1, RVS A FUSE, it's the sense line for the reverse control module. If the fuse is blown, it makes the module "think" the starter/reverse motor is overloaded.
    GO UK Wildcats, C.A.T.S. Cats! Cats! Cats!
    Rob's Candy Red '04
  5. #4
    Join Date
    Sep 2004
    Location
    ZEPHYRHILLS, FL
    Posts
    9,867
    Post Thanks / Like
    Default
    milage?
  6. #5
    Seasoned Member Wild Turkey's Avatar
    Join Date
    Dec 2008
    Location
    San Antonio, Texas
    Posts
    2,791
    Post Thanks / Like
    Default
    Don't park where you would have to back up.
  7. #6
    Seasoned Member Falcon's Avatar
    Join Date
    Dec 2008
    Location
    Round Rock, TX
    Posts
    272
    Post Thanks / Like
    Default Reverse
    Spray the Reverse switch backside with contact cleaner
    Stu McCurdy (Falcon)
    2009 Metalic Blue Limited Edition Goldwing Hannigan Trike
    Audio/Comfort/Navi/ABS w/XM Radio/Weather/Traffic
    2002 Escapade Trailer
    USAF 1964-1992
  8. #7
    Member
    Join Date
    May 2011
    Location
    Whitesboro TX
    Posts
    4
    Post Thanks / Like
    Question Silicon on backside of switch
    Nice Ride Falcon!!
    I've never been there, can you give me a hint or some directions on how to get to the backside of the switch?
    GreyGhost1950
    I,ve used silicon there before to no avail but had forgotten that. I'll look closer for a spring problem.
    techdude
    If the reverse fuse #1 fuse is blown, would the reverse function at all?
    GoldWingrGreg
    Milage is +/- 13k. MC was out of warrenty due to time when I purchased it.
  9. #8
    Join Date
    Sep 2004
    Location
    Lexington, KY
    Posts
    13,434
    Post Thanks / Like
    Default
    Yes, the reverse will work a little because there's a slight delay between the bike backing up and the module sensing the issue and stopping.
    Rob's Candy Red '04
  10. #9
    Join Date
    Oct 2007
    Location
    Central Texas
    Posts
    9,131
    Post Thanks / Like
    Default
    I would recommend a different Honda dealership or at least a different "technician". Many are not proficient at working on goldwings.
    ______________________________________________
    Ben
    Austin, TX area
    Many bikes and trikes since 1955, mostly BMWs. Currently looking for a motivated seller with the right Airhead.
  11. #10
    Seasoned Member caem's Avatar
    Join Date
    Oct 2008
    Location
    Camano Island Washington
    Posts
    304
    Post Thanks / Like
    Default
    Quote Originally Posted by techdude2000 View Post
    If the cables are OK, then check fuse #1, it's the sense line for the reverse control module. If the fuse is blown, it makes the module "think" the starter/reverse motor is overloaded.
    Where is this fuse I have the same problem I just had My Motortrike Spyder changed out for the Adventure kit after someone ran into me at a store before the change reverse worked fine now only 3 seconds
    2007 Crucible Orange Metallic 2011 Adventure MotorTrike formerly 2008 Spyder 2009 Crucible Orange Metallic Roll-A-Home
  12. #11
    Join Date
    Sep 2004
    Location
    Lexington, KY
    Posts
    13,434
    Post Thanks / Like
    Default
    Main fuse box to the left of your battery. If the fuse is good, you will need to measure the voltage at the fuse while backing up.
    Rob's Candy Red '04
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
