Fog lights interfering with radio
+ Reply to Thread
Results 1 to 7 of 7
Thread: Fog lights interfering with radio
  1. #1
    Contributing Member
    Join Date
    Feb 2012
    Location
    Cartersville, Ga
    Posts
    82
    Post Thanks / Like
    Default Fog lights interfering with radio
    Had my 2012 at the dealer today for the second time. When I turn my fog lights on while playing the FM it causes the signal to fade pretty severely. The dealer pulled out several 2012 models to check and see if it was related to a specific type of fog light. My bike as well as three other new ones all did it no matter what brand of lights that were used. The dealer called Honda in California to see if they were aware of the problem. They said that this is the first they had heard of it. Have any of you experienced this? it is hard to believe that this is not a wide spread problem if four out of four 2012 models all did it.
  2. Advertisements
  3. #2
    Seasoned Member Hoosier Daddy's Avatar
    Join Date
    Jun 2006
    Location
    Central Indiana
    Posts
    1,317
    Post Thanks / Like
    Default
    What brand of fog lights do you have if I may ask?
    2007 dark blue Navi
    Traxxion "Mega Monty"
    IBA #54656
  4. #3
    Join Date
    Oct 2011
    Location
    Fairbanks, AK
    Posts
    387
    Post Thanks / Like
    Default
    The light/radio interference was mentioned in at least one other thread I've read. I've put off installing any lower lights until there's more info...type and manufacturer of lights for example. At this point I assume it's a signal to noise problem, with the radio noise from the lights being loud and masking the signal.
    Gary
    2013 F6B Deluxe Red Geezer Wing
    And 48 others in the rear view mirrors since 1960
  5. #4
    Seasoned Member Len's Avatar
    Join Date
    Dec 2003
    Location
    Helotes, Texas
    Posts
    1,020
    Post Thanks / Like
    Default
    I have the genuine Hondaline fog lights and haven't experienced any problem.
    Proud owner of a 2012 Ultra Blue Level 4 from Schroaders Honda.
  6. #5
    Contributing Member
    Join Date
    Feb 2012
    Location
    Cartersville, Ga
    Posts
    82
    Post Thanks / Like
    Default Fog lights
    Quote Originally Posted by Hoosier Daddy View Post
    My lights are the kit from big bike parts, but the dealer also tested the Honda lights and they did the same thing.
  7. #6
    Seasoned Member jhughes556's Avatar
    Join Date
    Nov 2008
    Location
    Arlington, Texas
    Posts
    1,561
    Post Thanks / Like
    Default
    I had alot of problems on my 08 Airbag trying to use EC's High Output Fog lights and the CB radio. Really liked the lights but the squelch had to be turned up to 18 before the radio would cutting off. Same lights worked fine on a base model. Nothing we tried worked. Lewis was a big help but we never resolved the problem. I now have the Hondaline LEDs and they work fine...Hope this helps...
    "First Run Flat Tires on a Two Wheeler"
    2012 GL 1800 ABS
    2008 GL 1800 Airbag
    2002 GL 1800 Level 1
    1978 GL 1000 "Outrageous"
    1973 CB 750 Gold
    Darksider #443
  8. #7
    Join Date
    Oct 2011
    Location
    Fairbanks, AK
    Posts
    387
    Post Thanks / Like
    Default
    Quote Originally Posted by Kevimc View Post
    Is the problem present on AM, CB (AM), and FM?
    Is it across the frequency spectrum, or on specific or periodic or repeating frequencies?
    What do you hear in the audio when the lights are enabled on AM and FM? An increase in white background noise? A specific buzzing or odd sound?
    Does it happen when the engine is stopped and running only on the battery?
    You mentioned the dealer experienced the same problem with bikes with Honda lights. Did he park your's next to it and listen on yours for any interference from the other bike's lights, or visa versa? If it's on all, forget that test.
    There's folks here that have similar lights. Do they have a similar problem?
    My 2012's in the shop for warranty work and I don't have running lights yet or I'd contribute to the observations.
    Gary
    Edit: One thing that may help is to pinpoint the noise source(s). Take a portable AM/FM radio, turn it to each mode on low volume on a noisy frequency caused by the lights, then hold it near the lighted fog lights and elsewhere around the bike to find the loudest source. Try it with engine stopped, then again with the engine running. It might make more interfereing noise, or whatever it is you're hearing, next to the lights themselves if they're the problem. It may also be heard near the rear antenna (?), or in the bike's wiring near the relay panel under the seat (?). Not sure. Finding the loudest source should help Honda fix it. If the lights contain a noisy electrical circuit (?) that could be the problem.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Where do you live?
Your rides, Bikes, Cars?
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
