Difference between cruise control and a throttle lock on a 1800
+ Reply to Thread
Results 1 to 19 of 19
Thread: Difference between cruise control and a throttle lock on a 1800
  1. #1
    Join Date
    Dec 2003
    Location
    Phx AZ
    Posts
    665
    Post Thanks / Like
    Default Difference between cruise control and a throttle lock on a 1800
    On another thread someone was discussing a throttle lock and when someone ask why do you need one when a 1800 has cruise he got blasted and told not to hijack the thread.....
    Ok not PC but I live under a mushroom in the dark and get fed chit so I want to know what is the difference between a TL and CC?
  2. Advertisements
  3. #2
    Contributing Member bobkat44's Avatar
    Join Date
    Sep 2011
    Location
    Harvest Alabama
    Posts
    38
    Post Thanks / Like
    Default
    Throttle lock is manual and holds throttle position only. Speed will increase or decrease based on load. If your go up a hill speed will decrease and vice versa going down hill. True electronic cruise control will adjust to the load in order to maintain the speed that was set.
  4. #3
    Seasoned Member WAWingGuy's Avatar
    Join Date
    Dec 2009
    Location
    Sumner, WA
    Posts
    275
    Post Thanks / Like
    Default
    The very limited use for a throttle lock on an 1800 would be were you are going slower and/or in a lower gear than the CC will engage. Most of the time if you are in a situation that the CC will not function you really shouldn't be using it OR a throttle lock anyway. Might be usefull in a parade or slow freeway condition.
  5. #4
    Seasoned Member Degzi's Avatar
    Join Date
    Jul 2009
    Location
    Melbourne Australia
    Posts
    125
    Post Thanks / Like
    Default
    I have a throttle lock on my wing and I use it for situations where in need my right hand only for a moment and using the cruse will take longer. It is a good thing.
  6. #5
    Join Date
    May 2006
    Location
    Watching Karma unfold
    Posts
    11,439
    Post Thanks / Like
    Default
    There are many reasons why I use my Vista Cruise, and why others feel the need for one. My stock cruise has no lag at all (I adjusted it), and I still use my Vista Cruise more when not on the freeway for long stretches.
    My hand cramps up. Flipping a thump is faster than setting the OEM cruise.
    A bike without a CB is behind me, and I want to point at something on the road. (I hate using my foot)
    I want to point at something to a likewise rider. (cute butt bending over in a cage-Who wouldn't want a peek at that???)
    I feel like resting my hand on my lap for a brief time if traffic in clogged up on a back road for a minute or two?.
    I need to scratch an itch and can only get at it with my right hand.
    OEM cruise doesn't set at low speeds.
    These are some of the things I like about it. It's way faster to flip my thump than it is to use the OEM cruise. (I don't believe in leaving the cruise button in all the time).
    We all have different wants and needs and a throttle lock is just another one of those things that some find a use for,and some don't.
  7. #6
    Seasoned Member cgent's Avatar
    Join Date
    Mar 2006
    Location
    Winchester, Indiana
    Posts
    1,754
    Post Thanks / Like
    Default
    More importantly ... cruise control will instantly dis-engage when you hit the clutch or brakes ... a throttle lock will not ...
    Tom Batt ... the "FROGG TOGGS GUY"
  8. #7
    Seasoned Member Sailor_'s Avatar
    Join Date
    Sep 2007
    Location
    Bath, NC
    Posts
    794
    Post Thanks / Like
    Default
    Back when I had my 85 Aspencade I never used the throttle lock. It didn't
    make sense due to the reasons posted above (doesn't hold speed and will not
    auto-release).
    2008 GL1800
    Titanium Nav.
    Darksider #201
    Mitchelin Alpin PA3 195/55/16
  9. #8
    Seasoned Member WingMan71's Avatar
    Join Date
    Mar 2010
    Location
    Atlanta, GA
    Posts
    1,074
    Post Thanks / Like
    Default
    I'm with Rocky on this.
    I use my Vista Cruise throttle lock more than my cruise control for the same purposes that Rocky listed above. The Vista Cruise is just a convenience device.
    I don't use the Vista Cruise to hold speed over long distances, that's what I use my bike's cruise control for.
    No worries about disengaging a Vista Cruise either. When the tension is correctly adusted with the provided key, the throttle can be easily rotated to the off position even with the Vista Cruise ON. They are designed that way for safety. Plus I can manually disengage it with my thumb in a nanosecond at the exact same time I'm braking with both brakes. Not a problem.
    I wouldn't be without mine. Very handy device.
    Bob
    2006 Arctic White GL1800
    1987 Black/Grey GL1200 Aspencade
    1981 Blue/Blue CB750 Custom
    U.S. Navy SWO (1967-1976)
  10. #9
    DSI Keeper Murgie's Avatar
    Join Date
    Sep 2006
    Location
    WV
    Posts
    8,013
    Post Thanks / Like
    Default
    Since my camera is set up for a right handed user, I use mine all the time to snap photos. Especially handy for action shots and don't have the time for the cruise to set in.
    Quick shots like this are easier:
    Or last second thought of taking a shot like this:
    '14 GL1800 Red
    Keeper of the DSI numbers
    http://www.murgie.com/dsi_roster.txt
    FAQ (work in progress)
  11. #10
    Seasoned Member CruiseControl's Avatar
    Join Date
    May 2010
    Location
    Cascade, North Carolina
    Posts
    2,731
    Post Thanks / Like
    Default
    My muscles don't work right all the time, and I need all the help I can get.
    • I have the factory cruise control and leave it engaged so I can use it whenever I want.
    • I also have a Cramp Buster "cruise assist" so I don't have to grip as hard.
    • I will be getting a throttle lock and for all the reasons mentioned above plus a few more.
    I'll do whatever I need to do to be able to keep riding.
    Live, love, laugh,
    CruiseControl
    Relax and keep one eye on your future.
  12. #11
    Seasoned Member Joe In Calif's Avatar
    Join Date
    Jun 2004
    Location
    San Jacinto, Calif.
    Posts
    4,957
    Post Thanks / Like
    Default
    I have one on my Concours, works great for those times you just want to take your hand off the bars for a minute. It will hold speed if your on a flat road. All you have to do to release it is roll the throttle back or disengage it manually. It will not keep the throttle on if you want it off, it doesn't hold that tight. Best $20.00 I spent.
    DSCN0581
    If you are born once you wil die twice.
    If you are born twice you will die once
    RETIRED AND LOVING IT !!
  13. #12
    Seasoned Member Canyon Dancer in Colorado's Avatar
    Join Date
    Nov 2003
    Location
    Colorado, Loveland/Ft. Collins
    Posts
    2,463
    Post Thanks / Like
    Default What model
    What model Vista Cruise throttle lock do you use on the 1800? I have always had one on every bike I've had until the 1800 and couldn't find one that fit it correctly.
    If you have the model number of the lock, I'd sure appreciate your sharing it with me.
    It is a very convenient device especially at slow speed for all the purposes listed by others above.
  14. #13
    Seasoned Member 05nwl's Avatar
    Join Date
    Aug 2007
    Location
    Huntington Beach
    Posts
    3,651
    Post Thanks / Like
    Default
    Quote Originally Posted by Rocky View Post
    OK, now I get it. That would come in very handy.
  15. #14
    Join Date
    May 2006
    Location
    Posts
    11,439
    Post Thanks / Like
    Default
    Quote Originally Posted by Canyon Dancer in Colorado View Post
    Read my post (#4) in this thread with pictures of my mod's to make it fit and where I got it for a 1800. http://gl1800riders.com/forums/showt...-throttle-lock
  16. #15
    Join Date
    Nov 2003
    Location
    Posts
    2,463
    Post Thanks / Like
    Default Yes but.......
    Yes, I read that but they make a 1" handlebar diameter and a smaller one (I think it is 7/8") so I am wondering which one fits the 1800 bar. Thanks in advance.
  17. #16
    Seasoned Member Pooch's Avatar
    Join Date
    Nov 2010
    Location
    Utah's Area 51
    Posts
    3,244
    Post Thanks / Like
    Default
    Quote Originally Posted by cgent View Post
    the Brakeaway brand throttle lock will disengage when you hit the front brakes but it won't fit a Goldwing. I had one on my VTX 1300.
    PGR RC
    DDS
    #1146 IBA#55800 SS1K, BB1500, BBG, SS2K
    Certified, All DS!
    2010 Level 3 BS BT-45/Dunlop Wintersport DSST
    Disclaimer:
    This poster does not take any responsibility for any hurt or bad feelings. Reading threads poses inherent risks. This poster would like to remind readers to make sure they have a functional sense of humor before they visit any discussion board.
  18. #17
    Join Date
    May 2006
    Location
    Posts
    11,439
    Post Thanks / Like
    Default
    The same one (Part # 168 ) fits both the 1500 & 1800 7/8 bars. That is what's on my 1800 now. I took off my 1500 before I sold it. http://www.casporttouring.com/cst/mo...L1500/168.html
  19. #18
    Join Date
    Nov 2003
    Location
    Posts
    2,463
    Post Thanks / Like
    Default Thanks Rocky
    Thanks for the info Rocky, at a cost of $24.00, don't want to get the wrong one......7/8" gives me the info I need. Even tho I haven't had one on the 1800 since I bought it back in 2001, I still inadvertantly try to flip it on because my thumb "remembers it" on the 1980 1100 that I had and used all the time. It will be good to get it installed on the 1800. Thanks so much!
  20. #19
    Join Date
    Nov 2003
    Location
    Posts
    2,463
    Post Thanks / Like
    Default Got Vista Cruise installed
    Just finished installing the Vista Cruise throttle lock on the Dancer! I had to do some grinding on the tab that fits into the nipple under the handle bar cluster but being careful and fitting it a number of times has turned out perfect. Also had to grind the rivet head down so that the device would fit between the grip and the cluster. It is great to have it available to use at low speed when the cruise doesn't operate.
    Thanks Rocky for getting me started on this! Looks like original equipment too!
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Where do you live?
Your rides, Bikes, Cars?
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
