Volt meter inside speaker grill installed
+ Reply to Thread
Results 1 to 13 of 13
Thread: Volt meter inside speaker grill installed
  1. #1
    Seasoned Member MACKPILOT's Avatar
    Join Date
    Jul 2007
    Location
    HENDERSONVILLE, TN.
    Posts
    612
    Post Thanks / Like
    Default Volt meter inside speaker grill installed
    I got the idea from this board, I liked the one in the mirror the most but I went the easy way and put it in the speaker grill. It cost $12 on Ebay and is waterproof. Easy install.
    Click image for larger version.
    CERTIFIED IRON BUTT
    2008 METALLIC RED
  2. Advertisements
  3. #2
    Seasoned Member WB-Ron's Avatar
    Join Date
    Nov 2011
    Location
    West Bend, Wisconsin
    Posts
    2,880
    Post Thanks / Like
    Default
    Quote Originally Posted by MACKPILOT View Post
    I got the idea from this board, I liked the one in the mirror the most but I went the easy way and put it in the speaker grill. It cost $4 on Ebay and is waterproof. Easy install.
    Looks great. Clever idea.
    Ron
    2002 GL1800A - Darksider #1312
    "Experience is a hard teacher because she gives the test first,
    and the lesson afterward" ~ Vernon Sanders Law
  4. #3
    Join Date
    Jan 2012
    Location
    Virginia Beach, Va.
    Posts
    1,136
    Post Thanks / Like
    Default
    Looks good. Were instructions with it and how long did it take to install.
    Bob
  5. #4
    lightley seasoned member jburd's Avatar
    Join Date
    Mar 2004
    Location
    Niles, Mi.
    Posts
    3,130
    Post Thanks / Like
    Default
    Link ?
    John
    2001 GL1800 base
    IBA # 25535
    "Could you explain that to me as if I we're a particulary gifted child or a golden retriever?"
  6. #5
    Join Date
    Jul 2007
    Location
    HENDERSONVILLE, TN.
    Posts
    612
    Post Thanks / Like
    Default
    http://www.ebay.com/itm/120815079790...84.m1439.l2649
    I was wrong on the price, it was $12. I looked at so many that I forgot how much the one I got was. Above is the link. There are only 2 wires, red and black, I ran to the acc. post at the top of the fusebox. I used black silicone to hold in place but if I were to do it again I would just drill 2 little holes in the speaker grill and use 2 little black machine screws to hold it in.
    I just wanted it to be where it would be seen alot without thinking about looking for it and I was not happy with any other place: seemed to block the dash or navi or look really out of place everywhere else.
    CERTIFIED IRON BUTT
    2008 METALLIC RED
  7. #6
    Seasoned Member YJC's Avatar
    Join Date
    Feb 2012
    Location
    Lexington,N.C.
    Posts
    207
    Post Thanks / Like
    Default
    Cool..Looks good and when you check it -your vision is still good with the road...
  8. #7
    Seasoned Member Steve F's Avatar
    Join Date
    Apr 2011
    Location
    NOT in Chicago
    Posts
    2,934
    Post Thanks / Like
    Default They're cheap!
    I just had 2 delivered for $9 (yes, that's NINE dollars for two). I'm probably going to put it behind the mirror like was suggested a week or so ago.
    "To Ride Is The Reason...The Destination's The Excuse"
    Darksider #1358 09/12/12 MICHELIN ALPIN 195/55/16
    "Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote."
    Goldwing....1.8 litres of YEEEE HA!
    "....We don't need no stinkin' 6th gear!"
  9. #8
    Seasoned Member wing ryder's Avatar
    Join Date
    Sep 2006
    Location
    Florida's Space Coast
    Posts
    570
    Post Thanks / Like
    Default
    Nice Mack, I bet we'll start to see a bunch of these.
    Just curious, if (when) you have to remove the meter panel where do you un-hook the wires?
    To help your outlook, remember Who's looking out for you.
    Be nice, the more you do it the easier it gets.
  10. #9
    Join Date
    Nov 2006
    Location
    Ft. Lauderdale, FL
    Posts
    438
    Post Thanks / Like
    Default
    This works for me; same height as my main gauges. It's through the accessory circuit so the reading is the system voltage. My Battery Bug is hooked directly to the battery.
    I have a picture in my profile on the 2nd page of the back side wiring to show how it unplugs when removing the Meter Cover.
    2007, Dark Red Metallic with NAV & ABS
    Escapade color matched
    Zumo 665
    Michelin Primacy Alpin PA 3 195 55 16
    Darkside #486
    Galaxy Note 4 on Ram X-Grip for weather
  11. #10
    Seasoned Member Cottontop's Avatar
    Join Date
    Jun 2011
    Location
    Prairieville, Louisiana
    Posts
    170
    Post Thanks / Like
    Default
    I like to looks of it behind the spesker cover. Clever idea.
  12. #11
    chuckSTer
    Guest
    Default
    Great idea. Anybody know of an LED clock that would fit behind the other speaker cover?
  13. #12
    Join Date
    Aug 2008
    Location
    Lovely Marlette,Mi. In the heart of the Thumb.
    Posts
    1,220
    Post Thanks / Like
    Default
    Yeah,Pretty dang cool.
  14. #13
    Contributing Member
    Join Date
    Nov 2010
    Location
    Perkasie, PA
    Posts
    42
    Post Thanks / Like
    Default
    Nice installation, You have yours mounted behind the screen. I installed a Datek in the screen but I cut a rough hole with a Dremel then used a file to make a tight fit. The Datek has two screw terminals on the back for the wires.
    http://78gl1000.smugmug.com/Motorcyc...4888&k=tMBq7Vt
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
