Harbor Freight Motorcycle Wheel Cleaning Stand
+ Reply to Thread
Results 1 to 19 of 19
Thread: Harbor Freight Motorcycle Wheel Cleaning Stand
  1. #1
    Contributing Member reginaldmc's Avatar
    Join Date
    Dec 2011
    Location
    Pearland TX
    Posts
    82
    Post Thanks / Like
    Default Harbor Freight Motorcycle Wheel Cleaning Stand
    Has anyone tried the Harbor Freight Motorcycle Wheel Cleaning Stand on a Goldwing? It says it is rating for 500 lbs. Is that enough for either the front or rear tire?
  2. Advertisements
  3. #2
    Seasoned Member Wild Turkey's Avatar
    Join Date
    Dec 2008
    Location
    San Antonio, Texas
    Posts
    2,881
    Post Thanks / Like
    Default
    Looks like you could drive onto it with your front tire and then put it on the center stand. The front will spin while you clean it and the back will spin while in neutural. Let us know how it works, I might go by and get one myself. Beats trying to turn it by hand.
  4. #3
    Seasoned Member Larry Price's Avatar
    Join Date
    Jul 2007
    Location
    Puyallup, WA
    Posts
    4,098
    Post Thanks / Like
    Default
    If I need to spin the front wheel for cleaning I just use a scissor jack under the engine case with the bike up on the center stand. This works with the bike on the table lift as well. Easy peasy....
    Getting the wing off the center stand with that HF device is a struggle.... not so easy peasy....
    Larry Price
    Edgewood, WA
    I run Hybrid Tires....
    Front: Bridgestone Exedra G709 130/70R-18
    Rear: Michelin Primacy Alpin PA3 ZP 195/55R-16
  5. #4
    Seasoned Member wingd1800's Avatar
    Join Date
    Mar 2011
    Location
    Hudson Valley, New York
    Posts
    886
    Post Thanks / Like
    Default
    I had one and took it back. Had issues when putting on centerstand where tire was not in all the way between the 2 rollers. It would sit on only one roller. I have carpet in garage not sure if that has anything to do with it. I exchanged it for one of those little caster wheel seats to roll around on and clean the bike. Now that works great!
    2010 Titanium level 1 new 3/12/11 1981 GL1100S new 7/15/1981
    States from both my 1981 wing and my 2010 wing
    I love these Wings!!!
    Darksider # 1257 since May 2012 Michelin primacy alpin pa3 zp 195/55-16
  6. #5
    Join Date
    Jul 2007
    Location
    Puyallup, WA
    Posts
    4,098
    Post Thanks / Like
    Default
    Yes carpet is an issue, it sorta works ok on concrete getting it up on the center stand, but getting it off looks a little bit like a monkey and a football....
    Of course you could always just leave in on the side stand to do the front wheel.... shrug...
    Larry Price
    Edgewood, WA
  7. #6
    Join Date
    Dec 2004
    Location
    Modesto, California
    Posts
    600
    Post Thanks / Like
    Default
    I seem to remember a post several months ago on this same item. The poster said that the rollers were very hard to turn with weight on them as if they had very poor bearings. Maybe they have improved since then.
    Joe in Modesto
    '05 Blue 1800 ABS
  8. #7
    Seasoned Member stumpbucket's Avatar
    Join Date
    Sep 2010
    Location
    Southern Connecticut
    Posts
    1,224
    Post Thanks / Like
    Default
    Quote Originally Posted by wingd1800 View Post
    Carpet?? You have a fancy garage ey' I cant keep concrete clean how do you keep that nice?
    06 white Level 3 Traxxion
  9. #8
    Join Date
    Nov 2003
    Location
    Wi. Rib Lake
    Posts
    16,211
    Post Thanks / Like
    Default
    get a lift, Pitbull is a popular lift but expensive, most of the cheaper ones will work just as well for polishing wheels, then u can sit on a chair and be comfortable
    ehcycledude@yahoo.com
    02 GL1800 yellow 457,000 smiles
    Rode my bike to Trailer Week
  10. #9
    Seasoned Member USNRider's Avatar
    Join Date
    Apr 2011
    Location
    Virginia Beach, Va
    Posts
    654
    Post Thanks / Like
    Default
    Like others have said, the rear spins in neutral on the centerstand. For the front I grab the wheel and pull up (while on the centerstand) and it picks the front end up enough to turn the tire so I can keep cleaning it. Although, generally, I let the good lord clean it for me when he waters the earth.
    Learn to ride the bike, so the bike doesn't ride you when and if you ever need to use it to its full potential. Learning doesn't end when the MSF ridercoach hands you the BRC completion card.
  11. #10
    Join Date
    Nov 2008
    Location
    Barely
    Posts
    1,708
    Post Thanks / Like
    Default
    I have one, never use it. It's not a bad tool really, bearings are plenty OK for goldwing on the centerstand. The problems are lifting the front of the goldwing high enough to slip the wheel stand under. The goldwing is heavy to lift the front 2" off the floor while on the centerstand to slip the wheel cleaning stand under. It can be done, I did it, but then if the stand is not positioned just 100% perfectly perfect, the wheel when turned will walk off to one side or the other of the stand and make turning the wheel a chore rubbing on the frame of the cleaning stand. Much better to use the jack as mentioned or improvise some other means of lift.
  12. #11
    lightley seasoned member jburd's Avatar
    Join Date
    Mar 2004
    Location
    Niles, Mi.
    Posts
    3,130
    Post Thanks / Like
    Default
    Quote Originally Posted by stumpbucket View Post
    John
    2001 GL1800 base
    IBA # 25535
    "Could you explain that to me as if I we're a particulary gifted child or a golden retriever?"
  13. #12
    Seasoned Member Ric H's Avatar
    Join Date
    Nov 2011
    Location
    Canada
    Posts
    145
    Post Thanks / Like
    Default
    This works really well for me.And much steadier than a scissor jack under the engine.
    Click image for larger version.
  14. #13
    Seasoned Member Wingleader09's Avatar
    Join Date
    Jul 2009
    Location
    Hunterdon County, NJ
    Posts
    7,737
    Post Thanks / Like
    Default
    Quote Originally Posted by USNRider View Post
    Like others have said, the rear spins in neutral on the center stand. For the front I grab the wheel and pull up (while on the center stand) and it picks the front end up enough to turn the tire so I can keep cleaning it.
    You don't have to spend $30. With the bike on the center stand, it's easy to spin the front wheel.
  15. #14
    Seasoned Member WildBillLyle's Avatar
    Join Date
    Mar 2007
    Location
    Sandy Springs, GA.
    Posts
    780
    Post Thanks / Like
    Default Keep your money...
    It's a good concept but I found that the thing is probably meant for smaller bikes. it's not substantial enough to handle the Goldwing's weight. It supports the weight ok but when you spin the tire on it, the thing moves around and will not stay in a straight line. I give it a solid .
    2007 GL1800 Comfort Package
    "You are never too old to set another goal or to dream a new dream." - C.S. Lewis
  16. #15
    Seasoned Member keninsenm's Avatar
    Join Date
    Sep 2010
    Location
    Southeastern New Mexico, Lea County
    Posts
    889
    Post Thanks / Like
    Default
    Works OK for my trike!
    So long ... Pudge
    Southeastern New Mexico'06 gold GL 1800 with Roadsmith trike kit"
    Those who would give up liberty and freedom for safety and security deserve neither and will lose both" Benjamin Franklin
  17. #16
    Join Date
    Aug 2008
    Location
    Chicago, Illinois
    Posts
    1,514
    Post Thanks / Like
    Default
    I had one of those front wheel rollers. Took it back. It might work for a lighter bike, but the GW1800 puts way too much weight on the rollers for it to work.
    2007 Comfort/Nav/ABS
    Prior:
    1993 ST1100
    1983 CX650
    I'll go totally green and give up my GoldWing when Al Gore gives up his charter jet.
  18. #17
    Contributing Member cobra68's Avatar
    Join Date
    May 2011
    Location
    Big Rapids, MI
    Posts
    42
    Post Thanks / Like
    Default
    I have one of those and it works great. To get the bike on the rollers, I put the bike on the center stand, have the wife push down on the back of the bike and slide the rollers under the front wheel.
    Jim
  19. #18
    Join Date
    Oct 2006
    Location
    White Plains, MD
    Posts
    266
    Post Thanks / Like
    Default
    If you wait a while, it often goes on sale for about $19-22.
    BK
    07 Dark Orange ABS
  20. #19
    Contributing Member
    Join Date
    Nov 2010
    Location
    Foley,AL
    Posts
    53
    Post Thanks / Like
    Thumbs down
    I have one and never use it. Like Fluke189 said, the wheel will walk to one side and its hard to deal with. Spend your money on something else.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
