Cigarette lighter style plug for Garmin GPS
+ Reply to Thread
Results 1 to 14 of 14
Thread: Cigarette lighter style plug for Garmin GPS
  1. #1
    Seasoned Member cgent's Avatar
    Join Date
    Mar 2006
    Location
    Winchester, Indiana
    Posts
    1,780
    Post Thanks / Like
    Default Cigarette lighter style plug for Garmin GPS
    The cigarette lighter style plug for my Garmin Nuvi keeps coming unplugged from vibration as I ride down the road. These dumb things are dependent on a friction fit against a spring connection ... traditional but dumb design. I know I could cut the plug off the Garmin and wire it into the 'Wing through an SAE connection but I hesitate cutting off the molded on plug. Is there some nifty way to make a minor adjustment in the plug fitting so that the thing will stay plugged in until I want to unplug it ??? Only thing I can think of is to stuff the Goldwing pocket where the cigarette plug receptacle is full of "stuff".
    Any ideas ???
    Tom Batt ... the "FROGG TOGGS GUY"
  2. Advertisements
  3. #2
    Seasoned Member WB-Ron's Avatar
    Join Date
    Nov 2011
    Location
    West Bend, Wisconsin
    Posts
    3,327
    Post Thanks / Like
    Default
    Quote Originally Posted by cgent View Post
    Any ideas ???
    Tom, I'm not an electrician by any means, but can you do that without an in-line converter? I had considered the same thing at one time, but was lead to believe this is the case.
    Ron
    2002 GL1800A - Darksider #1312
    "Experience is a hard teacher because she gives the test first,
    and the lesson afterward" ~ Vernon Sanders Law
  4. #3
    Join Date
    Mar 2006
    Location
    Winchester, Indiana
    Posts
    1,780
    Post Thanks / Like
    Default
    I'm thinking of something as simple as a rubber band to hold the plug in place ...
  5. #4
    Seasoned Member 1 big skeeter's Avatar
    Join Date
    Nov 2007
    Location
    Houston
    Posts
    960
    Post Thanks / Like
    Default
    Try a small piece of stick on velcro around the plug body.
    2006 Wing
    2007 Tailwind XTc
    RAT Pack 2013
    IBA 55350
    DS 350
  6. #5
    Seasoned Member Bartman's Avatar
    Join Date
    Mar 2006
    Location
    Jacksonville, FL
    Posts
    8,886
    Post Thanks / Like
    Default
    Get something like this and just hard wire the damn thing.
    http://www.ebay.com/itm/GA-NHWC2-Gar...item3cbca099a1
    So long and good bye
  7. #6
    Seasoned Member SneakySnake's Avatar
    Join Date
    Jun 2006
    Location
    Western Kentucky
    Posts
    1,045
    Post Thanks / Like
    Default
    I realize this is not what you ask but thought it is worth mentioning. I would be careful cutting the plug off and hard wiring. If I am not mistaken, most if not all Nuvis operate on 5volts and is reduced in the plug. This is what I use. http://www.gpscity.com/gilsson-18-pi...wer-cable.html
    2002 Orange Goldwing DFT Trike
  8. #7
    Seasoned Member UNCLEJOHN's Avatar
    Join Date
    May 2009
    Location
    PALM BAY fl
    Posts
    9,280
    Post Thanks / Like
    Default
    Isnt cig plug have slots in it on side of it take n bend in so it grabs harder
  9. #8
    Seasoned Member pedro66's Avatar
    Join Date
    Mar 2009
    Location
    Las Vegas NV & Bartow FL
    Posts
    2,946
    Post Thanks / Like
    Default
    Pete
    "What is now proved was once only imagined."
    William Blake
  10. #9
    Seasoned Member Steve F's Avatar
    Join Date
    Apr 2011
    Location
    NOT in Chicago, just a little to the right
    Posts
    3,038
    Post Thanks / Like
    Default
    Three things come to mind.
    • The first is getting a receptacle that holds the plug better. In my truck, it has two outlets, one is a 12v socket, the other is a cig lighter, and the GARMIN comes loose if plugged into the outlet. consider getting a different socket.
    • The second is something like what PEDRO66 shows, which is a USB outlet. Only problem with most GARMINS is that they cannot use this without a special cord made to operate/charge a GARMIN through the USB port. They will usually think that you're plugged into the computer, and you cant do anything on the GPS
    • The third is to go to(not affiliated with) http://www.thegpsstore.com/Default.a...m_medium=email or something like that, and they have a 12v lighter powercord that's made to operate GARMINS through the USB port without problems, and I have found that this one is small and light enough that it stays plugged in the socket and won't work it's way loose.....but, if you use the GPS as an MP3 player, this thing isn't filtered as well as the GARMIN plug, and you get alternator whine in the audio
    "To Ride Is The Reason...The Destination's The Excuse"
    Darksider #1358 09/12/12 MICHELIN ALPIN 195/55/16
    "Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote."
    Goldwing....1.8 litres of YEEEE HA!
    "....We don't need no stinkin' 6th gear!"
  11. #10
    Seasoned Member DJ Fire's Avatar
    Join Date
    Apr 2007
    Location
    Greenback, TN
    Posts
    6,422
    Post Thanks / Like
    Default
    Take the plug apart and toss the plastic casing.
    Heat shrink or tape the "guts" to protect em from misc crap.
    You will have two wires soldered to the plug's contact "pads". Cut the pads off and discard. Wire those leads to your power supply and you're done.
    This can be placed under the pocket so you do not lose any space and no longer have the disconnect problem. I have done this on 8 bikes for friends plus my own bikes.
    RIP Mom - I Love You
    8-2-1945...2-12-2011
    2009 HD Road King Police
    2008 Suzuki DRZ400sm
    2007 Wing
    2006 Suzuki Intruder (FOR SALE)
    1985 Honda Nighthawk (Special Edition)
    RKMC (Red Knight Motorcycle Club)
    RCME (River City Motorcycle Escorts)
    SERF (Safety Escort Riders of Florida)
    Riding Consultations:
    firefitr@cxp.com
    Slow speed control & tighter turning:
    http://gl1800riders.com/forums/showt...7590&posted=1#
  12. #11
    Contributing Member
    Join Date
    Jan 2010
    Location
    Lucerne, Indiana
    Posts
    66
    Post Thanks / Like
    Default
    Tom, I had the same trouble. I crosscut a couple of deep scratches in the friction metal strips on the plug.....enough to leave a slightly rough edge. We rode about 370 miles and it never came out. I suppose at some point I will have to rough it up again but it has worked for a while..........
    Gene
  13. #12
    Join Date
    Nov 2011
    Location
    Posts
    3,327
    Post Thanks / Like
    Default
    Quote Originally Posted by DJ Fire View Post
    DJ this ones a little harder to do than the pics of the passenger headset plug you posted the other day but, if you get a chance some pics of this mod might be helpful too. Thanks.
    Ron
  14. #13
    Join Date
    Apr 2007
    Location
    Greenback, TN
    Posts
    6,422
    Post Thanks / Like
    Default
    oh boy... okay....
    um.... Might be faster to send a PM to TexasWolf69. Her's was wrapped in clear electrical tape.
    Let me see what I can do but give me a day or two and I will just do a project review.
    2007 Wing
    firefitr@cxp.com
  15. #14
    Seasoned Member Scott1's Avatar
    Join Date
    May 2010
    Location
    Cranberry Township Pennsylvania
    Posts
    535
    Post Thanks / Like
    Default
    Try bending the long power spring clip (on the plug) out to get more friction.
    Greg
    Current Stable:
    2008 GL1800 Level 3 W\2010 Motortrike Adventure IRS Kit
    1999 Valkyrie Interstate W\2002 Lehman Trike Kit
    2009 Vulcan 900 Classic (Girlfriends)
    1996 Bunkhouse Trailer
    1999 Harbor Fright Piggy Trailer
    Derek Weaver W-1500 Motorcycle Lift
    GWRRA Pennsylvania Chapter "D"
    I always have the time to answer a PM.
    I believe in helping fellow bikers and when possible paying it forward.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Where do you live?
Your rides, Bikes, Cars?
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
