Bleeding Brakes on Hannigan trike
+ Reply to Thread
Results 1 to 3 of 3
Thread: Bleeding Brakes on Hannigan trike
  1. #1
    Seasoned Member ectrike's Avatar
    Join Date
    Feb 2009
    Location
    Howard KS
    Posts
    144
    Post Thanks / Like
    Default Bleeding Brakes on Hannigan trike
    Does any one know hou to bleed the brakes on a Hannigan trike?
  2. Advertisements
  3. #2
    Join Date
    Oct 2007
    Location
    Central Texas
    Posts
    9,242
    Post Thanks / Like
    Default
    Quote Originally Posted by ectrike View Post
    Use whatever method and equipment you are comfortable with on car brake systems. The principle is the same.
    ______________________________________________
    Ben
    Austin, TX area
    Many bikes and trikes since 1955, mostly BMWs. Currently looking for a motivated seller with the right Airhead.
  4. #3
    Seasoned Member Sonney's Avatar
    Join Date
    May 2007
    Location
    Rosedale IN.
    Posts
    465
    Post Thanks / Like
    Default Bleeding Breaks
    Left, right, Frt. pump up until the petal is up and open your bleeder let the air out. Keep doing this until you see no bubbles. Hook up an clear plastic tube on bleeder. Use box wrench on Bleeder. Frt break is still in the system. Make sure the reservoir is always full. Don't expect a firm break pedal it will be a little soft. JMO
    Sonney
    Money Pit
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
