Bike has 5 wire trailer plug and trailer has 4 wire plug -- Adapter???
+ Reply to Thread
Results 1 to 13 of 13
Thread: Bike has 5 wire trailer plug and trailer has 4 wire plug -- Adapter???
  1. #1
    Contributing Member hwilks's Avatar
    Join Date
    May 2012
    Location
    Bryant,Ar
    Posts
    58
    Post Thanks / Like
    Default Bike has 5 wire trailer plug and trailer has 4 wire plug -- Adapter???
    Guys,
    Is there an adapter that converts the 5 wire plug on the bike to the 4 wire on the trailer.
    If so where can I buy one?
    thanks,
    Hwilks
  2. Advertisements
  3. #2
    Seasoned Member GoldwingRon's Avatar
    Join Date
    Oct 2010
    Location
    New Jersey
    Posts
    526
    Post Thanks / Like
    Default
    http://wingstuff.com/products/27916-...ness-converter
    Sorry that it's not from DLP, but this was the one I used. Easy as pie to install.
    2010 Pearl Yellow
    Comfort Navi-XM
    (GL1800HPNM)
    With guns, we are 'citizens'; without them, we are 'subjects'
    *NEW JERSEY
    NRA Life Member
    AOPA Member
    GWRRA Member
    GWTA Member
    AMA Member
  4. #3
    Join Date
    Oct 2010
    Location
    New Jersey
    Posts
    526
    Post Thanks / Like
    Default
    http://wingstuff.com/products/2679-t...isolated-relay
    You may want to add one of these too in order to maintain isolation from the rest of the bike's electronics...
    2010 Pearl Yellow
    Comfort Navi-XM
    (GL1800HPNM)
    *NEW JERSEY
    NRA Life Member
    AOPA Member
    GWRRA Member
    GWTA Member
    AMA Member
  5. #4
    Seasoned Member Dakota Triker's Avatar
    Join Date
    Nov 2011
    Location
    Pierre, SD, US
    Posts
    525
    Post Thanks / Like
    Default
    The 5th wire is a brake circuit and is most likely unused. Clip it.
  6. #5
    Contributing Member JAM's Avatar
    Join Date
    May 2007
    Location
    Cedar Springs, Mi.
    Posts
    51
    Post Thanks / Like
    Default
    Quote Originally Posted by Dakota Triker View Post
    This is not true. On your goldwing you have seperate wires for each turn signal, running lights, ground and the extra wire is for your brake lights. Do not clip it or you won't have brake lights on your trailer. If your trailer has one wire for turn signals and brake lights (4 way) then you will need an adaptor. If you have seperate turn signals from your brake lights (5 wire) just get a 5 wire plug.
    JAM
    07 Dark Red Navi/Comfort/Audio/ABS
  7. #6
    Seasoned Member WB-Ron's Avatar
    Join Date
    Nov 2011
    Location
    West Bend, Wisconsin
    Posts
    3,131
    Post Thanks / Like
    Default Same but different
    Sorry to tag on to the OP's question, but this seemed like a logical time to ask. Is there a plug that will do the same conversion in reverse, i.e. a 4 pin flaT plug on the bike to a 5 pin on the trailer?
    Ron
    2002 GL1800A - Darksider #1312
    "Experience is a hard teacher because she gives the test first,
    and the lesson afterward" ~ Vernon Sanders Law
  8. #7
    Seasoned Member eidolon's Avatar
    Join Date
    Jun 2011
    Location
    3rockfromsol
    Posts
    155
    Post Thanks / Like
    Default
    Maybe I do not understand the question but I do not think there is an adapter that will turn a five wire plug into a four wire plug. I think you will have to change the plug/wiring on one or the other.
    Either a five wire on the trailer or get the converter and wire up a four wire on the bike.
    But as I said I may not understand the question you are asking...
    seeya
    eidolon
  9. #8
    Seasoned Member Patdcop's Avatar
    Join Date
    Oct 2011
    Location
    Aurora MO.
    Posts
    115
    Post Thanks / Like
    Default
    Quote Originally Posted by WB-Ron View Post
    No sir, you will have to re-wire the trailer to match the bike. If the trailer is 5 wires you probably have independent (amber) turn signals and separate (red) brake and turn.
  10. #9
    Seasoned Member chalayko's Avatar
    Join Date
    Nov 2007
    Location
    Victoria, B.C.
    Posts
    397
    Post Thanks / Like
    Default
    I just went through this with my Nissan Pathfinder, 5 wires out to a 4 pin connector on the trailer. I got an adapter from the local U-Haul trailer rental place for $17.99. Product number 14486. The red wire from the car/bike is the brake light circuit. Hope you have a U-Haul nearby. Cliff. http://www.uhaul.com/MovingSupplies/...-Flat?id=13684
    2007 GL1800
    1971 CB750 bought new
    1971 CB750 restored
    1969 CB750 under restoration
    1965 CA95 Benly waiting for love
    1968 CM90 Cub waiting for love too.
    1980 CB750F
    "Every time I start thinking the world is all bad, then I start seeing people out there having a good time on motorcycles. It makes me take another look." - Steve McQueen
  11. #10
    Join Date
    Jan 2011
    Location
    centennial, colorado
    Posts
    362
    Post Thanks / Like
    Default converters
    You can get converters to go either way, absolutely. A isolater is a very good idea on the motorcycle, get it. Park nose out for safety. A five wire has the brake seperate from the turn signals. On cars and trucks the turn signals do a combination in the turn signal switch, or multifunction switch as they call it today.
    Go by function not wire color
  12. #11
    Seasoned Member BACKDRAFT's Avatar
    Join Date
    Dec 2004
    Location
    Northwest Florida Panhandle
    Posts
    4,360
    Post Thanks / Like
    Thumbs up
    www.electricalconnection.com
    They have everything you will need to make it happen.
    Hope this helps
    Be sure to wave back!
    _________________________________
    Prowler 27
  13. #12
    Seasoned Member Destindoc's Avatar
    Join Date
    Oct 2007
    Location
    Western Montana
    Posts
    1,925
    Post Thanks / Like
    Default
    As stated, bikes have five wires... one brake, one for each turn signal, one for tail light, one ground. Five total, unlike cars that have brake lights double as turn signals and just need four. Best be informed before advising people..... there are several companies that make a "5 to 4" converter for those who have a trailer wired the standard way.
    2008 Goldwing ABS
    2004 CBR 1000 RR
    2009 KLR 650
    ...wife has her own 2006 Goldwing...
    A stop at the top of Beartooth Pass.
  14. #13
    Join Date
    Mar 2010
    Posts
    365
    Post Thanks / Like
    Default
    The problem of throwing on some type of adapter and riding off is that without installing an isolator, the bikes wiring is taking the entire load of the trailer's lights. Depending on what you have added to the bike already and the number of lights on the trailer, it my just be too much
    Mark
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Where do you live?
Your rides, Bikes, Cars?
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
