Dino Oil to Synthetic Oil and Back
+ Reply to Thread
Results 1 to 12 of 12
Thread: Dino Oil to Synthetic Oil and Back
  1. #1
    Seasoned Member Rosy's Avatar
    Join Date
    Oct 2010
    Posts
    107
    Post Thanks / Like
    Default Dino Oil to Synthetic Oil and Back
    I am sorry if this thread was already posted, but I couldn't find it.
    Here is my question:
    Is it true that you shouldn't switch dino oil to synthetic oil then back to dino oil in your Wing or any other motorcycle engine? If this is true, what is the reason?
    I also know the newer engine are tighter and need sysnthetic oils in automobiles, but are the newer motorcycles engines being made tighter to pass EPA rules like the automobile engines?
    Thanks for your input!
    Regards,
    Rosy
    From NH
  2. Advertisements
  3. #2
    Join Date
    Jan 2006
    Location
    Texas
    Posts
    8,254
    Post Thanks / Like
    Default
    I am guessing that since the Goldwing engine is going on 13 years old, it would not be classified as a "newer" engine requiring synthetic blends.
  4. #3
    Join Date
    Apr 2011
    Location
    Emmett, Id
    Posts
    1,766
    Post Thanks / Like
    Default
    Nah. Old wife's tale. Swap from dino to synthetic and back as often as you like. I don't have a clue how that rumor got started but lots of folks still believe it.
    A few year ago had the mechanic at my local BMW shop tell me that my bike (R1100RT) would go belly up if I ran Mobil 1 oil in it but Amsoil (which amazingly enough he happened to sell) was fine.
  5. #4
    Seasoned Member TXREALTOR's Avatar
    Join Date
    Jan 2009
    Location
    Trinidad, Tx
    Posts
    3,240
    Post Thanks / Like
    Default
    In the 1980's and 90's this was deemed as "true". Not sure why, other than the oil companies may just wanted to keep you once they had you.
    As for modern oils, it is ok to switch back and forth.
    Cheers
    Cheers and Good Riding, Keith
    DROP, FALL, AND DOWN ARE 4 LETTER WORDS
    I, my typing, and spelling are far from perfect. Get over it.
  6. #5
    Join Date
    Jan 2005
    Location
    Indiana
    Posts
    7,631
    Post Thanks / Like
    Default
    No problem switching but, for the life of me, I can not think of any good reason to switch from syntheic to dino
  7. #6
    Join Date
    Apr 2004
    Location
    Morganville, New Jersey / Naples, Florida
    Posts
    3,014
    Post Thanks / Like
    Default
    The engine's in our Goldwings might have a 13-year design, but they are still made new every year. I wouldn'r hesitate to use synthetic oils or swap back and forth as you please.
    One way or t'other enjoy your slippery decision.
  8. #7
    Seasoned Member jlbc212's Avatar
    Join Date
    Apr 2012
    Location
    Massachusetts, 30 miles N of Boston
    Posts
    833
    Post Thanks / Like
    Default
    Quote Originally Posted by tfdeputydawg View Post
    Synthetics usually cost substantially more, unless the interval between oil changes is greatly extended. I prefer to change my oil frequently, usually every 3 thousand miles, so I use dino oils.
    Jack
  9. #8
    Seasoned Member 2WheelNut's Avatar
    Join Date
    Nov 2012
    Location
    Arlington, Texas
    Posts
    2,387
    Post Thanks / Like
    Default
    Oh goody, an oil thread.
    It's been over 10 days since the last one and I was having withdrawals.
    My opinion...
    Switch back and forth all you want. Unless you are pushing ultimate performance doing some kind of Goldwing race series or trying to squeeze 15K miles out of an oil change, synthetics are not necessary, but it's your money, so spend it how you want..
    I do like the feel of the clutch when using a MC specific oil that is designed for a wet clutch application so I will always use a MC specific oil. Other than that, get the viscosity that matches your seasonal temps that is within spec for the bike, change per the manual, and have fun riding as many miles as you want before you get tired of the bike.
    Some people will say you should use synthetic oil or change more often than the manual requires because it's "cheap insurance" but those same people will not be able to produce a single GL1800 that had a wear related engine failure before 300K miles (providing that maintenance was done at least as often as Honda specifies) that would have been prevented by synthetic oil. Insurance should protect you from a disaster that you don't want to pay for. If there is nothing to protect from, I wouldn't call it's cheap insurance, more like a small donation to some oil companies bottom line that makes you feel better.
    But hey....there's nothing wrong with feeling better. Think of all the chrome that gets sold because people like the way it looks.
    Current Stable:
    2015 Yamaha FZ-09
    2013 Honda GL1800 ABS
    2007 Suzuki GSXR 600 (track)
    2004 Suzuki GSXR 750 (track)
    2004 BMW F650GS
  10. #9
    Seasoned Member bgross's Avatar
    Join Date
    Apr 2009
    Location
    SoCal
    Posts
    4,535
    Post Thanks / Like
    Default
    I'm not sure not sure if this qualifies as a "good" reason, but...
    Maybe someone's oil is due for changing, and their finances are tighter than usual. So they decide that, if they buy Dino oil instead of Synthetic, they'll have money left for gasoline?
    Since Mother Honda doesn't require Syn., many the correct formula/wt. of Dino is... Good Enough?
    to the OP:
    when you drain & change oil & filter, there is still oil left in your engine. Even if you use the same type of oil, you are mixing the two types of oil that should concern all of us the most - clean oil and dirty oil.
    Clean oil good! Dirty oil bad!
    You are a 'go' for launch. Change your oil.
    B. Gross
    IBA #57164
    '02 GL1800ABS "Rose"
    '03 FJR "Lucille"
    "The World is my country, all mankind are my brethren, and to do good is my religion." - Thomas Paine
    "Be Polite. Be Professional. But have a plan to kill everyone you meet." - General James N. Mattis, USMC
    "If you meet the Buddha on the road, kill him." ~ Linji Yixuan
    Darksider # 764
    Michelin Primacy Alpin PA3 ZP ~ "You'll shoot your eye out, kid."
    "Enjoy Every Sandwich." ~ Warren Zevon
  11. #10
    Seasoned Member jerrieric's Avatar
    Join Date
    Jun 2009
    Location
    Windham Maine
    Posts
    3,645
    Post Thanks / Like
    Default
    One good reason I have is my '06 likes Rotella 15w40 better than any of the expensive syn's I have tried and I have tried allot of them. I think one has to find out what works best for them. I tried Amsoil, Mobil 4T race, Rotella T6 and other syns and I like the Rotella 15w40 the best. Oh and I change only every 8k per the manual. The 15w40 only costs $13 at Wally World. Only ran DINO in my '89 Wing for 92k and 16 years. Never had an issue.
  12. #11
    Join Date
    Dec 2008
    Location
    Spring, TEXAS
    Posts
    2,182
    Post Thanks / Like
    Default
    NOW WAIT A MINUTE----JUST HOLD ON---ya`ll mean ya got to change oil in a Goldwing??????
  13. #12
    Contributing Member
    Join Date
    Jan 2012
    Location
    Central Ohio
    Posts
    90
    Post Thanks / Like
    Default
    Quote Originally Posted by xregandyx View Post
    Nope --- I've gone into the dealership two different time for an oil change and came out with a new Wing.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
