GL2Way CB and GMRS Radio - Hideous Squeal
+ Reply to Thread
Results 1 to 9 of 9
Thread: GL2Way CB and GMRS Radio - Hideous Squeal
  1. #1
    Notorious Rocket Scientist The Astute Reader(tm)'s Avatar
    Join Date
    Mar 2008
    Location
    Baltimore, Maryland
    Posts
    5,449
    Post Thanks / Like
    Default GL2Way CB and GMRS Radio - Hideous Squeal
    Greetings!
    When I have my GL2Way set to use both the CB and the GMRS radio at the same time, everyone on the CB side hears a loud, piercing squeal when I xmit. The squeal is there even if I disconnect the GMRS radio. I have to disconnect the cable to the GMRS to make the squeal go away.
    Suggestions? Would a ferrite on the GMRS cable help?
    Best Regards,
    Lee E. Brown
    "Greetings from Herkheimer Industries!"
  2. Remove Advertisements
    GL1800Riders.com
    Advertisements
  3. #2
    Seasoned Member MidMoWing's Avatar
    Join Date
    Jul 2011
    Location
    Fulton, Missouri
    Posts
    630
    Post Thanks / Like
    Default
    When I first installed my GL2Way, any time I pushed the transmit button, there was a horrible squeal. I even had Pete on the phone trying to help me sort it out. In the end, it turned out what the problem was the little black box thing (yes, I know all the technical jargon and names for components) that was some inline component of the GL2Way was lying against my J&M Bluetooth unit. It was the simple fact they were touching in the trunk subcompartment that was causing it. The instant I separated them, and only by an inch or so, all the squealing stopped.
    It's possible that my situation was unique, but it's worth a look. Keep that little square thingy away from everything else.
    If I wasn't at work, 20 miles from my bike, I could be more specific. Sorry about that.
    2010 Black GL1800
  4. #3
    Seasoned Member pedro66's Avatar
    Join Date
    Mar 2009
    Location
    Las Vegas NV & Bartow FL
    Posts
    2,932
    Post Thanks / Like
    Default
    Quote Originally Posted by The Astute Reader(tm) View Post
    Greetings!
    Yes if you unplug the cable and the noise stops put two filters on the FRS cable wrapped a few times it should stop
    Because your GL2WAY is kicking out a fair amount of power the cable can become a kind of reception antenna
    Pete
    "What is now proved was once only imagined."
    William Blake
  5. #4
    Join Date
    Mar 2008
    Location
    Baltimore, Maryland
    Posts
    5,449
    Post Thanks / Like
    Default
    Quote Originally Posted by pedro66 View Post
    I presume you mean ferrite filters? Are these something that I can purchase from you? If so, please let me know.
    Best Regards,
    Lee E. Brown
  6. #5
    Seasoned Member pidjones's Avatar
    Join Date
    Sep 2006
    Location
    Clinton, TN
    Posts
    4,082
    Post Thanks / Like
    Default
    They should be available at Radio Shack, or you can cut them off of old CRT input cables.
    Sent from my LePanII
    Love 'em all... Let GOD sort 'em out!"
    LIMNCS #632 DS#1085 Michelin Primacy Alpin PA3 ZP #19
    Trialsman Seminar Videos
    Swapping the Rear Wheel by Laying Her Down (youtube)
  7. #6
    Seasoned Member Wingleader09's Avatar
    Join Date
    Jul 2009
    Location
    Hunterdon County, NJ
    Posts
    7,737
    Post Thanks / Like
    Default
    You can get them at Radio Shack.
    http://www.radioshack.com/product/index.jsp?productId=2103222
    http://www.radioshack.com/product/in...lickid=prod_cs
  8. #7
    Join Date
    Mar 2008
    Location
    Baltimore, Maryland
    Posts
    5,449
    Post Thanks / Like
    Default
    Thanks for the tip! I wasn't sure what size I would need so I ordered one of each. I hope this fixes it.
    Best Regards,
    Lee E. Brown
  9. #8
    Join Date
    Sep 2006
    Location
    Brier, WA
    Posts
    109
    Post Thanks / Like
    Default
    Exactly the fix I did for exact same problem.
    -martin
    2005 CBC GL1800
  10. #9
    Join Date
    Mar 2008
    Location
    Baltimore, Maryland
    Posts
    5,449
    Post Thanks / Like
    Default
    Quote Originally Posted by mlk View Post
    Cool! Thanks for the info.
    Best Regards,
    Lee E. Brown
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
