Plug under the left pocket. Acc power?
+ Reply to Thread
Results 1 to 8 of 8
Thread: Plug under the left pocket. Acc power?
  1. #1
    Seasoned Member MarkEkberg's Avatar
    Join Date
    Sep 2009
    Location
    Belmont NH Bought the house I grew up in 12/12
    Posts
    1,844
    Post Thanks / Like
    Default Plug under the left pocket. Acc power?
    I am adding a acc power to the left pocket. Under it I found a red plug. Is this for a Honda plug and play acc outlet?
    SHOW ME A GOVERNMENT THAT WILL GIVE YOU EVERYTHING YOU NEED AND I WILL SHOW YOU A GOVERNMENT THAT WILL TAKE EVERYTHING YOU HAVE.
  2. Advertisements
  3. #2
    Join Date
    Jun 2007
    Location
    Gilberts, IL
    Posts
    467
    Post Thanks / Like
    Default
    That's it.
    Mark
    2006 Goldwing (Gold)
    Patriot Guard Riders
  4. #3
    Seasoned Member sur48's Avatar
    Join Date
    Nov 2011
    Location
    florida
    Posts
    3,510
    Post Thanks / Like
    Default
    Quote Originally Posted by MarkEkberg View Post
    yes should be 2 wire
    You are hereby officially PROWLER #83.
  5. #4
    Join Date
    Sep 2009
    Location
    Posts
    1,844
    Post Thanks / Like
    Default
    Cool. Didn't get the Honda one cause no one around here has anything Goldwing related, but I will tap into those wires.
    Thanks!!
  6. #5
    Seasoned Member Doctoss's Avatar
    Join Date
    Nov 2010
    Location
    Memphis, TN
    Posts
    442
    Post Thanks / Like
    Default
    I believe there is a round cutout in the pocket for a plug also.
  7. #6
    Seasoned Member ssncob's Avatar
    Join Date
    Nov 2010
    Location
    Crossville TN
    Posts
    5,112
    Post Thanks / Like
    Default
    Quote Originally Posted by Doctoss View Post
    No, just the outline of where the hole will go. You still get to cut it out. Note - make sure the hole and the item you are going to use are the same size. After -market plugs may not be the same size.
    Double Darksider #847
    IBA #54767 BB1500+
    Patriot Guard
    Who I was yesterday is but a past memory, who I will be tomorrow is in the future. Who I am now and the type of person I am to others, that is what is important now.
  8. #7
    Contributing Member GortsBud's Avatar
    Join Date
    Apr 2013
    Location
    Atlanta (Smyrna), GA
    Posts
    79
    Post Thanks / Like
    Default
    Yah and don't believe it when your friend says "Oh, piece of cake. I can drill that hole." Huh huh. He drilled a hole all right.
  9. #8
    Join Date
    Mar 2008
    Location
    Vancouver BC
    Posts
    1,920
    Post Thanks / Like
    Default
    Thanks!!
    No don't it is for low amp systems only
    Tie a relay into these wires so that the relay is energized by it
    Tie contact side of relay to batt thu a fuse and use that to power aux devices
    Click image for larger version.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
